disable P0300 test
Old Dec 23, 2008 | 07:43 AM
  #136
Ted B's Avatar
I had previously dropped an "0001" bomb into periphery 2, which puts a "1" into Bit 0, and a "0" everywhere else. I believe that takes care of the evap, secondary O2, etc./
Old Dec 23, 2008 | 09:34 AM
  #137
psphinx81's Avatar
Im not that familiar with what that means lol.
step by step at how to do that? do i leave the sensors for the EGR plugged in
Old Dec 23, 2008 | 02:10 PM
  #138
psphinx81's Avatar
bumpy!
Old Dec 23, 2008 | 02:55 PM
  #139
Ted B's Avatar
If you add the "Periphery Bits" code to your XML (see post #1), you will see one of the bit tables labeled as "Periphery 2". Basically, you use the increment/decrement buttons ( [] ) to toggle all of these to "0" except for Bit 0 (leave that one as "1"). That will take care of it.
As for whether you leave the sensor plugged in or not is up to you. It's probably better to leave it plugged in than to have loose pigtails dangling.
Old Dec 23, 2008 | 02:58 PM
  #140
psphinx81's Avatar
ok got it!
thanks a bunch ted, greatly appreciated!
Old Dec 24, 2008 | 12:55 PM
  #141
D-VO's Avatar
This is just an update to let everyone know that after 6 weeks I still have absolutley no issues with disabling the P0300 code. I used to get the ses all the time for this error.
Old Jan 12, 2009 | 07:51 PM
  #142
evodood's Avatar
mrfred- Does disbaling the p0300 effect ay of the other P03xx series codes? specifically p0301, p0302, p0030 and p0304 ?
Old Jan 12, 2009 | 08:37 PM
  #143
mrfred's Avatar
It kills them all. :-)
Old Jan 12, 2009 | 08:59 PM
  #144
evodood's Avatar
Yeah that's what I'm afraid of. I hate the generic "something is wrong but I don't know really what." of the P0300. Which is why I'd like to kill it, but not necessarily at the expense of the "I know what happened and it was in cylinder 1,2,3,4" of the 301, 302, 303, 304 codes.
Course, now that I think about it, those codes could really only tell you if a plug or coil is bad.....possibly injector....I'd sure feel a power it if I lost a cylinder or two, so maybe I don't need those anyway. hmmmmmm......time to reconsider this.
Old Jan 13, 2009 | 07:02 AM
  #145
Mellon Racing's Avatar
I gave mine the bomb and will simply re-enable it if I have a problem I need to check on
Old Jan 14, 2009 | 03:59 PM
  #146
evodood's Avatar
Interresting option also, thx. Maybe when the V6 comes out I'll kick this to the curb.
Old Jan 17, 2009 | 09:02 PM
  #147
Steiner's Avatar
A little confused here. I'm running ROM# 96940011 for an '05 VIII. I've already added the 1.35 periphery bit code to my ROM, and edited bits 4 and 5 in Periphery2 accordingly. My question is do I also follow the instructions below or am I done and ready to reflash?
"If you are using an older version of ECUFlash, then copy the entry shown below to your XML file (save the xml file, and then relaunch ECUFlash):
<table name="ECU Periphery2" category="ECUPeriphery" address="fca" type="1D" level="1" scaling="Hex16"/>
When you open the Periphery2 entry, you should see: EFDF. Change it to EFCF by typing "0xEFCF" (without the quotes) and then pressing return. If you see something other than EFDF, post it up here, and I'll give you the correct value to enter."
Old Jan 18, 2009 | 08:33 AM
  #148
mrfred's Avatar
Both methods accomplish the same thing, so if you were able to directly edit the bits with the periphery bit table, then you're done.
Old Jan 18, 2009 | 11:55 AM
  #149
Steiner's Avatar
Thanks for the clarification mrfred. And thanks for this fix!
Old Jan 18, 2009 | 12:25 PM
  #150
fusionevo's Avatar
How do I open my ROM to fix this? I've had the p0300 for years and I run with an ODBII reader in my car just so I can reset it as I drive.
I have a 03 evo8 and EcuFlash 1.4... I just don't know how to open the xml ROM to modify that part of it.
