disable P0300 test
Old Nov 24, 2008 | 01:29 AM
  #121
GotWheelHop's Avatar
Originally Posted by Evoryder
Hair spray and zipties. I used to suffer from the same issue. If you take off the upper strut bar you gain better access. If you take off the throttlebody you can see where the infamous hose is. Also towards the passenger side there are some hoses that tend to pop off. Well worth the scrapes on the forearm to get them suckers ziptied!
Yeah, I have done the hairspray mod there. It works wonders on IC pipes too.
Old Nov 24, 2008 | 11:11 AM
  #122
Colt4g63's Avatar
This seems to be working for me as well. I got a nice RUFF cold start where it would usually ALWAYS pop the code up. But now no more P0300 My car is an 03 and the rom ID is 94170008
Old Nov 24, 2008 | 12:01 PM
  #123
wesside's Avatar
Originally Posted by EVO8URV8
Hot start, warm start, cold start, no start, whatever start, got no problems here whatsoever [so far]. (I even disable the other annoying p0401 code that I'm getting.)
Thank u, mrfred. U tha man.
I get the same damn p0401 I had hoses pop off before but now randomly get it and all the hoses are connected so not sure I might turn it off too
Old Nov 24, 2008 | 12:38 PM
  #124
mt057's Avatar
600+ miles with no p0300 code! Everyday I wake up and think it will come back but it doesnt. I used to get it constantly. Thank you mrfred. I have not had it using ecuflash 1.34 or after switching to the 1.40
Old Nov 27, 2008 | 09:35 PM
  #125
FX11's Avatar
btw i passed NY inspection and emissions test with egr and 0300 tests off
Old Nov 28, 2008 | 09:35 AM
  #126
magyar86's Avatar
thats awesome, im going to disable mine and go see if it will pass here in texas.
Old Dec 15, 2008 | 04:45 PM
  #127
grazzo77's Avatar
For those of you out there that this had fixed your issue, did you feel the stutter or "Machine gunning?
Old Dec 15, 2008 | 05:20 PM
  #128
Evoryder's Avatar
stutter is gone because....*drum roll* ...there is no more code! lol
Old Dec 16, 2008 | 08:28 AM
  #129
mitsuorder's Avatar
Yep. Made my car enjoyable again
Old Dec 16, 2008 | 09:05 AM
  #130
JohnBradley's Avatar
Everyone that has been able to pass, can you please document exactly what bits you had on and what ones were off? trying to compile a list so know our "boundaries". I know that anything to do with the O2 heater that is disabled will not pass (at least in OR), but it seems that the 56D8 to turn off the test will. I havent tried the 5.08+/Mrfred patch to simulate the rear O2 and see what it will do though.
Old Dec 16, 2008 | 10:42 PM
  #131
Aaron, I turned periphery bit 2 to the value Mrfred posted in his original post(edit...it was actually EDCF that I changed it to, in my ROM). It disabled my p0300, and my EGR readiness test. The monitor shows up as not supported, so the OBD2 check overlooks it. I couldn't get my EGR to set the day prior to doing the periphery bit mod, so the car wouldn't pass as the monitor wouldn't switch to ready. I am also running Tephra's 5.1 patched 94170015 rom, with the o2 sim enabled, and had no issues whatsoever. I do have the o2 sensor plugged in to not trip the heater CEL though.
Old Dec 20, 2008 | 03:40 PM
  #132
Mellon Racing's Avatar
I've had that pesky p0300 for eons, ever since I installed the HKS 280 cams and the problem followed me with the BF272 as well on the new built shorty/head.
I tried this fix today and it vanished and never came back after hours of driving (usually comes right back)
thanks guys, the SES light didn't bother me personally but people riding with me would be making a big deal about it
Old Dec 22, 2008 | 07:50 PM
  #133
psphinx81's Avatar
i just did this in my rom. now thats its disabled i can take all that garbage off the back of my IM correct? then run a block off plate for the egr
Old Dec 22, 2008 | 08:54 PM
  #134
Ted B's Avatar
Correct. Basically, you've disabled the ECU's check routine for the EGR, so it won't even bother to look to see if it is there.
Old Dec 23, 2008 | 04:02 AM
  #135
psphinx81's Avatar
awesome, thanks! do i have to leave the sensors plugged in or can i get rid of those too?
what about the evap stuff in the rear? what do i need to do to the ecu to get that out with no codes
