The stock ECU has gear dependent boost control!
Old Nov 25, 2008 | 06:06 AM
  #121
MR Turco's Avatar
Tephra, GREAT STUFF! I am really looking forward to this!
Old Nov 25, 2008 | 07:00 AM
  #122
mfr122887's Avatar
Would it be possible to use one of the 6 columns for when the car is not moving....stationary rev limiter?
Old Nov 25, 2008 | 07:35 AM
  #123
MR Turco's Avatar
what would you need that for?
Old Nov 25, 2008 | 07:38 AM
  #124
mfr122887's Avatar
So you can run 100% duty cycle to get more boost. Not really that important but the column is going to be wasted anyway on a 5sp so it was just a suggestion to a possible use.
Old Nov 25, 2008 | 07:50 AM
  #125
phenem's Avatar
I really like that idea! Unfortunetly I don't think my clutch and drivetrain would.....
Still, a great idea and would be something to consider if it can be done easily with this mod....
~Zach
Old Nov 25, 2008 | 07:53 AM
  #126
dan l's Avatar
Wow this past week has been amazing. If your sitting back and thing its not a big deal between the knock code understanding and this you need a reality check. We can now do more with the stock ecu than multi thousand dollar standalones could 5 years ago. Not only that but it retains turn key reliability and drive ability.
Old Nov 25, 2008 | 07:56 AM
  #127
MR Turco's Avatar
not to mention the ability to pass inspection!
Old Nov 25, 2008 | 09:16 AM
  #128
travman's Avatar
Makes me want to grab a box of beer and celebrate.......
Old Nov 25, 2008 | 02:27 PM
  #129
RazorLab's Avatar
Found something interesting in comparing the Evo 10 USDM GSR and the USDM MR maps:
The GSR isn't using the gear-dependent boost but it looks like the MR is in the form of bringing down the boost via the BDEL table (WGDC tables are the same)
Mrfred, does this look it's limiting it in 1st and 2nd gear in the MR according to that RPM/MPH crossover on the MR?
Old Nov 25, 2008 | 04:27 PM
  #130
mrfred's Avatar
I attached an Excel workbook with the rpm/mph values for the USDM Evo Xs (2nd tab in the workbook). It looks like for both the GSR and the MR, the crossover is between 1st and 2nd gear, so only 1st gear is using the Low Gear Range tables.
Interestingly, for the GSR, Mitsu put the crossover between 1st and 2nd gear, but the high and low gear range tables are the same. For the Evo 8/9, Mitsu put the crossover way above 1st gear.
File Type: zip
Old Nov 25, 2008 | 04:46 PM
  #131
RazorLab's Avatar
Oh I didn't see that you put the Evo X in your worksheet, thanks!
Old Nov 25, 2008 | 04:49 PM
  #132
mrfred's Avatar
Just added it a few minutes ago. The earlier copy doesn't have it. :-)
Old Nov 25, 2008 | 04:55 PM
  #133
RazorLab's Avatar
Ah ok, thought I was going crazy, thanks for adding that!
So it looks with the OEM tune, the MR uses less boost only in 1st and only around peak torque, after 5500 rpm, it's the same.
Old Nov 25, 2008 | 04:58 PM
  #134
mrfred's Avatar
Yep. Maybe change the crossover to between 2nd/3rd, and add more boost in 1st/2nd gear than other gears. In 1st/2nd gear, the tires will spin before the clutch slips. :-))))
Old Nov 27, 2008 | 05:39 PM
  #135
tephra's Avatar
So the coarseness of that variable is becoming a problem, 4th gear pull:
You can see that between 3063 and 3313 rpm the WGDC jumps up and down.
I can only assume this is because the ECU is interpolating to the 3rd gear.
Any ideas?
