The stock ECU has gear dependent boost control!
Old Apr 9, 2009 | 06:42 AM
  #211
WRC-LVR's Avatar
Originally Posted by WRC-LVR
Has anyone done the 88580014 ROM for gear dependent boost ? I have a friend Im helping tune his rom and would like to do this for him.
Specifically the address needed...I 'm OK with the table itself and the calculation as well as what tables to modify for WGDC and BDEL
Thanks in advance
Milburn
Still need the address for this 88580014 ROM !! Bump for those people using this ROM . Gurus' please help out !!!!!
Milburn
Old Sep 27, 2009 | 09:58 AM
  #212
shadow1's Avatar
mrfred, the gear ratios listed for the 05 VIII GSR/RS cannot be correct. My gearing takes me well past 160 at 7000 rpm in 5th (my speedo says 165). I suspect the 03/04 five speed gearing is the same as the 05 five speed gearing.
Old Sep 27, 2009 | 10:06 AM
  #213
mrfred's Avatar
If you can verify the correct ratios, I'll update my file and repost it.
Old Sep 27, 2009 | 10:09 AM
  #214
Jack_of_Trades's Avatar
Look at my dyno simulator for the final drive,3rd and 4th gears at least.
Old Sep 27, 2009 | 11:06 AM
  #215
shadow1's Avatar
I did some searching and the VIII GSR/RS tranny (03-05) is the same as the JDM VII (7) tranny. So the the ratios listed for the 03-04 five speed are correct and apply to the 05 model as well.
Old Sep 13, 2010 | 05:26 AM
  #216
shadow1's Avatar
Old but still relevant thread. Any suggestions for tuning WGDC for 5th gear without driving my max speed of 170+ on public roads? I currently overboost in 5th using my 1st-4th gear WGDC.
Old Sep 13, 2010 | 10:39 AM
  #217
D-VO's Avatar
You should probably use a general interpolation for the 5th gear colomn against the first four, if that makes any sense. Other than that, you already know 5th overboosts so make an adjustment according to that as well.
Old Sep 13, 2010 | 10:45 AM
  #218
neonglh's Avatar
Yeah, tune it on a dyno
Old Feb 6, 2012 | 11:27 AM
  #219
CRONZ305's Avatar
my rom untouched has
Boost Control High/Low Gear Range RPM/MPH Crossover
is that all i need to make adjustments? and i run a jdm map 3 gm 3 port if that means anything
id like to separate as follow
1-3 have same boost profile
4-6 have another
Old Mar 11, 2015 | 01:21 AM
  #220
Thugline's Avatar
Sorry for the noob questions,but what is the definition of "BDEL" and what is the "crossover"?
Old Mar 11, 2015 | 01:25 AM
  #221
tephra's Avatar
boost desired engine load
basically target load
Old Mar 11, 2015 | 01:48 AM
  #222
Thugline's Avatar
I'm really confused as to what rpm/mph values are. Why is it that the mph is high for the lower gears and low for the higher gears.
Old Mar 11, 2015 | 09:02 AM
  #223
mrfred's Avatar
rpm/mph is the ratio of engine rpm to vehicle speed. rpm/mph is a set number for each gear, lower gears have higher values because the engine rpm is higher relative to vehicle speed, e.g., 7000 rpm in first gear is maybe 40 mph giving a ratio of 7000/40 while 7000 rpm in 5th gear is probably ~150 mph, giving a ratio of 7000/150. I forget the exact values now (maybe they are in the first post?), but the idea is to select an rpm/mph value that is between the value for the gears where you want the boost transition to occur.
Old Mar 11, 2015 | 10:32 AM
  #224
RazorLab's Avatar
Yes the rpm/mph are in the first post as an attached PDF.
mrfred
Dec 15, 2022 11:13 AM
tephra
Aug 1, 2018 01:02 AM
richardjh
Jul 28, 2017 03:49 PM
chetrickerman
Jun 23, 2017 10:02 AM
tephra
151
Jun 18, 2017 03:22 PM
