The stock ECU has gear dependent boost control!
Old Nov 18, 2008 | 04:51 AM
  #106
tephra's Avatar
all the normal rom's.
this is exclusive of the psi/load based boost control. it will be upto the user to still perform these modifications.
not hard thou
Old Nov 18, 2008 | 08:47 AM
  #107
logic's Avatar
Originally Posted by taenaive
Anyone here made it work for 96940011 ROM yet?
Dang, I wish I have a different rom....
So use a different ROM, then.
Old Nov 18, 2008 | 09:34 PM
  #108
taenaive's Avatar
Wow... Dang! It works on 9694011 rom
I found that I put wrong endian values for my ECUFlash Version.
Now, I got strong low gear boost! Oh yes!
Thank you all!
Old Nov 24, 2008 | 01:33 PM
  #109
fostytou's Avatar
EvoM Community Team
Awesome tephra!
Old Nov 24, 2008 | 02:09 PM
  #110
tnt1106's Avatar
Originally Posted by fostytou
Awesome tephra!
+1 looking very forward to this.
Old Nov 24, 2008 | 02:19 PM
  #111
jcsbanks's Avatar
If you go over the end of the map it just uses the last value when you use the ECU's usual interpolation routines.
The speed reading is very coarse indeed. I wonder if you might be better using speed as an input to a gear number map, and then using gear number as a lookup for your boost table. This will make the gear judge discrete rather than continuous. If for some odd reason someone had large gaps between two adjacent gears this would then avoid hunting and poor boost control. The beauty is that all the ECU code to do these stages of lookup is there, just load up the registers with your addresses and write the correct headers in your lookup maps.
Originally Posted by tephra
right guys.
slight problem.
the RPM/Speed variable isn't all that accurate, ie it can be several points of. Now this is fine for the in between interpolation, but what happens at the extents of the map?
ie if our last column is 6th gear, which is roughly 25rpm_per_kph, now for whatever reason the RPM/Speed variable is reading 20, how does the ECU interpolate past the end of the map?
Old Nov 24, 2008 | 02:25 PM
  #112
tephra's Avatar
Actually the system seems to be working quiet well.
Doing another run this morning so I will post up my log and WGDC table.
Yeah it wasn't hard to add the 3d table, especially since I already had done the Tephramod stuff.
Release will be pretty soon
Old Nov 24, 2008 | 03:11 PM
  #113
lapulapu's Avatar
Tephra, will this work with the PSI base system or do we have to convert back to the load?
Old Nov 24, 2008 | 05:28 PM
  #114
mrfred's Avatar
I was thinking the stock rpm/mph variable might be too coarse as well, but its worked fine in my limited testing as well.
No prob to use psi-based control.
Old Nov 24, 2008 | 05:29 PM
  #115
tephra's Avatar
I have a graph to post up - just busy atm.
I will setup the tables as per original rom (ie load), it will be upto the user to change to PSI... Should be fairly easy (just scaling change)
Old Nov 24, 2008 | 07:33 PM
  #116
tephra's Avatar
voila:
There is some uppy-downy ness due to the rpm's droping, presumably just bad shifting on my behalf.
Thoughts?
I can post the full XLS if anyone likes!
edit - thats a 1st, 2nd, 3rd log, ie first 3 columns of 3dmap.
Old Nov 24, 2008 | 08:05 PM
  #117
mrfred's Avatar
Its always kind of hard for me to judge from time plots. Does having the per gear rpm/mph help with boost control?
Old Nov 24, 2008 | 08:10 PM
  #118
tephra's Avatar
yes! booting it in 1st now yields significant gains, car feels a LOT stronger. For 1/4 mile guys this will be a big deal.
that's RPM on the X-axis.
Old Nov 24, 2008 | 08:35 PM
  #119
mrfred's Avatar
Ack. I see. I think its the scaling on the plot that got me. It looks different for each gear.
Old Nov 24, 2008 | 08:37 PM
  #120
tephra's Avatar
Sorry, yeah it was a consecutive upshift rather than breaking down to 2500 todo a pull per gear.
If you want I can do:
1st - 2500 - 7000
2nd - 2500 - 7000
3rd - 2500 - 7000
