The stock ECU has gear dependent boost control!
Old Nov 10, 2008 | 05:30 AM
  #46
MR Turco's Avatar
Originally Posted by Jorge T
Not using a tephra ROM just a 94170008 ROM... maybe when I changed the load variable for boost control the crossover got disabled?
can you change the higher gear WGDC to something really low and see if it switches to that? I believe Tephra mentioned in some thread that the resolution for WGDC doesn't actually have the .5% resolution that we enter in and rounds to a different value (hopefully he can chime in). Try putting like 20% in there just to see what it does.
Old Nov 10, 2008 | 06:05 AM
  #47
Jorge T's Avatar
I'll try to do that, but I would think that a difference from 51 to 55 would be logged. I did not see a difference in the 3 logs I did.
Or maybe I'm logging the wrong wgdc(id86)?
Old Nov 10, 2008 | 07:32 AM
  #48
mrfred's Avatar
Originally Posted by Mattjin
FYI, the auto cars heavily rely on gear dependance for not just the boost, but also main fuel and ignition map selection. They use one map for 1st and 2nd gear and another for 3rd, 4th,5th gears. Maybe some browsing through the code may help to see if the same can be applied to other roms to allow the same feature.
Now that we know there is an rpm/mph RAM variable, it can be exploited to write whatever gear dependent map switching patches that makes sense. Someone has just gotta do it.
Originally Posted by Deepseadiver
Wow you guys are great! I would think that the EVO X should have some of the same type of maps for the boost. I can't wait till it available.
gunzo is very good and working hard at it. In a few more weeks or months, he'll have worked out everything that we have for the 9 and more.
It has to be which maps you are using. I'll have to look at my 94170008 disassembly to determine which maps matter.
Old Nov 10, 2008 | 07:48 AM
  #49
dudical26's Avatar
Nice find. I think this will be very usefull for tunning for consistent boost across all gears. I use PSI based boost control and I tend to have slightly lower boost in 1 & 2 gear. It will be nice to be able to raise the WGDC in 1st & 2nd to help get the boost up higher. We all know how cool AWD burnouts are, lol.
Old Nov 10, 2008 | 10:22 AM
  #50
chrisw's Avatar
hey tephra,
maybe you can throw away the p0300 code block now that we know how to turn it off with bit flags. Or the lean spool code?
Old Nov 10, 2008 | 11:00 AM
  #51
EvoBroMA's Avatar
Originally Posted by Jack_of_Trades
This is awesome. I'd say its especially useful for people running the load targeting rather than the JDM map and PSI targeting. I know my car hits totally different boost levels in 4th than it does with third since the load values change and the ECU tries to hit my taget load values in my BDEL table. So there were 4 BDEL and BWGDC tables originally right? So now only 2 of them are proven to do anything?? Sorry, trying to catch up here.
like me.
Old Nov 10, 2008 | 10:02 PM
  #52
tephra's Avatar
what about something like:
of course this is only a demo to show what *could* be done...
Old Nov 11, 2008 | 01:48 AM
  #53
jcsbanks's Avatar
Looks ideal.
Old Nov 12, 2008 | 12:23 AM
  #54
SkyNight's Avatar
Originally Posted by jcsbanks
Looks ideal.
Me too
Old Nov 12, 2008 | 03:26 AM
  #55
tephra's Avatar
only problem with using a 3dmap for gears is that i can't use a 3dmap for MAP/RPM...
but maybe thats no so important.
I need to do some logs of 100% WGDC until 18-20psi then normal WGDC's vs normal WGDC's from 0psi..
Old Nov 12, 2008 | 05:08 AM
  #56
MR Turco's Avatar
omg! I can has!?
Old Nov 12, 2008 | 06:17 AM
  #57
C6C6CH3vo's Avatar
You think this also ties into X-Tau?
Old Nov 12, 2008 | 07:31 AM
  #58
dudical26's Avatar
This looks amazing. Is this something you think you would do?
Old Nov 12, 2008 | 08:13 AM
  #59
MR Turco's Avatar
Tephra, the only thing i would possibly suggest is to just have the gear number instead of the RPM/MPH if possible. I know it is simple to figure out but just for ease of use.
Old Nov 12, 2008 | 08:25 AM
  #60
l2r99gst's Avatar
The rpm/mph is different for every transmission, though. So, putting the gear number wouldn't help. Leaving rpm/mph is the only way to know the true setting that you need.
