Knock control - load vs RPM table found
Old Dec 3, 2008 | 03:19 PM
  #196
Ted B's Avatar
I did, and it was an absolute success.
Whereas I had been reduced to using an ignition map that made things feel as though something was wrong, I reloaded the factory map values (offboost load cells) and went out for a drive. The result was a HUGE improvement with not one flash of knock, and that is to be expected being that I can now use 25 deg advance in cells where I had been reduced to 12 deg.
The car now feels like it's always rolling downhill, and I can guarantee with absolute sincerity that using an HTA82 with T4 1.06 twinscroll kicks *** in everyday driving. As soon as I get moving from a stop, this thing feels like it's taken an on-ramp to hellaciousness, with no knock CEL, and I haven't even tuned it yet!
Old Dec 5, 2008 | 07:08 AM
  #197
D-VO's Avatar
Adjusting the low rpm knock multiplier to 19 and the mid to 22, definatly made the knock load adjustment better. Thanks jcsbanks. I've got no low load knock issues in any gears.
Old Dec 5, 2008 | 02:15 PM
  #198
scheides's Avatar
EvoM Moderator
LOL I just spend the last 6 hours at work jumping off and reading this thread, it is so amazing it is absolutely addictive!
jcbanks and everyone else, THANK YOU for figuring this out. VERY VERY impressive and I'm going to give it a go, I'm on 96530006.
Old Dec 5, 2008 | 06:03 PM
  #199
scheides's Avatar
EvoM Moderator
LOL I just left my office to go try this on the drive home and oops, tons of snow! Soon enough....
Old Dec 6, 2008 | 08:21 PM
  #200
whitey4d's Avatar
Does anyone know the xml for the 9642008 ROM?
Old Dec 9, 2008 | 11:21 AM
  #201
scheides's Avatar
EvoM Moderator
Bump, anyone else played with this yet? Snow snow snow here, WOT = wheelspin city for me
Old Dec 9, 2008 | 06:39 PM
  #202
whitey4d's Avatar
I want to but I havent seen the xml for the 9642008 ROM and Ive read I think the whole thread.
Old Dec 10, 2008 | 01:48 AM
  #203
jcsbanks's Avatar
The wiki doesn't have 96420008 to download. All you need are the three values for the multiplier for knockbase calculation. They are probably very near to other Evo 8 addresses.
Old Dec 10, 2008 | 05:46 AM
  #204
mlocatel's Avatar
Thanks al\lupo
Originally Posted by al\lupo
Try this:
Code:
  <table name="Knock Control" category="Knock Control" address="3cf6" type="2D" level="2" scaling="Load8">
      <table name="X" address="6d56" type="X Axis" elements="10" scaling="RPM"/>
  </table>
  <table name="Knock Multiplier" category="Knock Control" address="6558" type="2D" level="2" scaling="uint8">
      <table name="X" address="8034" type="X Axis" elements="14" scaling="RPM"/>
  </table>
  <table name="Knock Adder - Triple Gain" category="Knock Control" address="656c" type="2D" level="2" scaling="uint8">
  </table>
  <table name="Knock Adder - Single Gain" category="Knock Control" address="6580" type="2D" level="2" scaling="uint8">
  </table>
Old Dec 10, 2008 | 03:59 PM
  #205
whitey4d's Avatar
IF I sent you my ROM would you be willing to look at it? I do intermittently get low load knock but nothing horrible. But once I build the engine with forged internals soon Id rather be ready for it.
Old Dec 11, 2008 | 08:25 PM
  #206
Dapper Dan's Avatar
Im finally gonna test this out tomorrow, I have a few counts of knock around 3500 rpms that will not go away.
Old Dec 12, 2008 | 11:17 AM
  #207
mplspilot's Avatar
Has this fixed the low load tip in knock issue for 94170015 users? (Sorry if it's been mentioned.) I would guess it has, maybe it's time for me to try and switch out my 0008 for the 0015 (again.)
Old Dec 12, 2008 | 11:23 AM
  #208
Ted B's Avatar
I can confirm that it has completely eliminated phantom knock in my case.
Old Dec 12, 2008 | 11:47 AM
  #209
evo8dad's Avatar
Ditto for me as well as a dozen or so of my customers
Old Dec 12, 2008 | 02:03 PM
  #210
jcsbanks's Avatar
96420008:
Multipliers:
177a 13
24aa 18
21de 20
For those trying to disassemble, if you find the first value at 137a or 177a, the routine that references this address has the other two addresses called nearby. It is ultimately called from the longsub_inj 802Hz called from CMT0 interrupt (vector 2F0 in all SH2).
