The definitive EcuFlash Evo 10 thread
Old May 8, 2009 | 08:23 AM
  #496
mrfred's Avatar
Originally Posted by otbEVO
Not to be off topic, but what O2 sensor simulator are you running on the X?? Or will it even be necessary to do so once you guys figure out how to turn off the CEL using ECUFlash??
None. It hasn't been ported over to the X yet. I'm still primarily working on Evo 8/9 disassembly. tephra will likely do the port.
Old May 8, 2009 | 11:57 AM
  #497
otbEVO's Avatar
Gotcha. Thanks for the quick reply.
Old May 9, 2009 | 06:30 PM
  #498
nj1266's Avatar
I was fidling around with ECUflash ver 1.41 and clicked on options from the file drop down menu.
There are new options that I do not understand.
Under "Debugging" there is the "show J2534 calls." When you click it, you get a check button with "send all J2534 calls to debugger." What does that do? Should I enable this with a check sign in the box next to the text?
There is also "Show Open Port 2.0 Raw Communictions." What does that do? And should I enable it?
Finally, there is "Flash Recovery Mode" What does that do? And should I enable it?
Old May 9, 2009 | 07:16 PM
  #499
SiC's Avatar
SiC
Under "Debugging" there is the "show J2534 calls." When you click it, you get a check button with "send all J2534 calls to debugger." What does that do? Should I enable this with a check sign in the box next to the text??
This is for developers to send the calls from ECUFlash to an external debugger program for analysis of it's communication, etc.
There is also "Show Open Port 2.0 Raw Communictions." What does that do? And should I enable it??
This is for the above, to send raw communications to a debugger program.
Only enable this when you brick an ECU. When you brick one, enable this option and use a jumper on pins 8 & 12 on the OBD2 port using a breakout box and flash back to stock.
Old May 9, 2009 | 08:04 PM
  #500
nj1266's Avatar
What is a breakout box? Where do I get one for jumper pins 8 & 12?
TIA
Old May 10, 2009 | 03:40 AM
  #501
SiC's Avatar
SiC
TIA
This is what it looks like (the one I have) and you can buy it here. This is also the one Colby uses, but he uses the more expensive 3 port.
Old May 10, 2009 | 08:16 AM
  #502
nj1266's Avatar
So how is it used. Do you have a step-by-step breakdown on how to use this? Do I simply connect the cable side (male) to the OBD2 port and the other side (female) to the tactrix cable and the the Tactrix cable to the lap top? Then what do i do?
TIA
Old May 10, 2009 | 08:28 PM
  #503
SiC's Avatar
SiC
TIA
PM'd
Old May 10, 2009 | 10:41 PM
  #504
burnings's Avatar
Hi Sic,
Can I ask what is the kind of range of figures you are seeing in ecuflash fuel map on the 800cc injectors?
As I am about to put them in but from my last experience, the cell values WOT seems to be in the 18s, 19s and yet the AFR is still piggy rich.
Another thing I am asking on behalf is you mentioned that the Mivec map are used to prevent the high cams from stalling the vehicle, do you actually turn up the values in the low load cells to achieve that?
Old May 11, 2009 | 12:38 AM
  #505
SiC's Avatar
SiC
Originally Posted by burnings
Hi Sic,
I have a feeling that your Fuel Injector Scaling address is wrong. The correct address is "536cc", some of the older XML files had the wrong address that would still give the same value of 532 cc/min but it wouldn't change anything when messing with the values. Open up ECUFlash and check the Fuel Injector Scaling address to make sure it's 536cc. After you edit the address use these values if you like. These values are from my car with Cos Cams so it may not work well for all Evos:
Injector Scaling
696
Injector Latency
4.61v 5.904
6.96v 5.664
9.30v 3.024
11.57v 2.040
13.92v 1.536
16.26v 1.128
18.53v 0.816
Old May 11, 2009 | 02:03 AM
  #506
burnings's Avatar
Injector Scaling
696
Injector Latency
4.61v 5.904
6.96v 5.664
9.30v 3.024
11.57v 2.040
13.92v 1.536
16.26v 1.128
18.53v 0.816
When i changed the address to 536CC, the default value is 287...
Old May 11, 2009 | 02:33 AM
  #507
AIK's Avatar
AIK
Answer me, what it for the table? I try will learn to build xml-files, here have found.
Attached Thumbnails The definitive EcuFlash Evo 10 thread-xml1.bmp   The definitive EcuFlash Evo 10 thread-fuel.jpg
Old May 11, 2009 | 03:31 AM
  #508
SiC's Avatar
SiC
What ROM ID do you have?
I just checked, you must have 52360016, the old JDM 5MT.
Old May 11, 2009 | 04:15 AM
  #509
burnings's Avatar
52360016... The xml is also 52360016.xml
Is there an updated one???
Old May 11, 2009 | 05:20 AM
  #510
SiC's Avatar
SiC
52360018 is the latest 5MT one, I suggest you work off of that one instead.
