ECU Corrupted – need HELP rom# 96420008
Old Nov 30, 2008 | 08:38 PM
EVO8speed's Avatar
Originally Posted by lan_evo_mr9
How do you alter the ecu id? A simple no would have been fine. lol
Lan evo mr9,
I really apreciate you spending so much time working on my ROM. Thanks for getting my car running again!! I can finally sleep!
Kevin
Old Nov 30, 2008 | 08:40 PM
Dapper Dan's Avatar
I guess you got it running again? Well I sent you another rom anyways haha.
Old Dec 1, 2008 | 06:04 AM
lan_evo_mr9's Avatar
No problem Kevin, I like challenges. I know when my rom got corrupted, I too couldn't sleep at night wondering what the hell was going on with my car. I will have to admit, I liked the way the cars looked sitting there next to each other.
Somewhat off topic but,
Why would you want to change the ecu id? When I pull up my rom and some others, it doesn't even have one. What's the point is what I guess I'm asking.
Old Dec 1, 2008 | 06:51 AM
PVD04's Avatar
Several tuners would change the ECU ID to scramble their tunes and keep people from reading them. I first came across it when downloading a Dynoflash tune for a friend. On his ROM, 94170008 had been changed to 96420011 so EcuFlash used the wrong xml file and therefore did not show the correct data.
-Paul
Old Dec 1, 2008 | 08:03 AM
How nice of them(dynoflash). Good to know, thanks for the info.
Old Dec 1, 2008 | 07:05 PM
EVO8speed's Avatar
I just want to let everyone know what I've learned from this whole thing
1. some '03 and '04 Evo's using ECU Flash can have the issue where when you go to retrive the data you loaded it will appear scewed (in my case the ignition tables had the X and Y axis values all random) but it was entered correctly. I learned that while it appears to be corrupted, so long that you entered it with the right values, its ok. this just seems to happen with some '03 and '04 Evo's when you retrive the data from the ECU.
2. I also lost the immobilizer code in this whole process - long story - but I also learned and will confirm tomorrow that the mitsu dealership can re-flash your car with the orignal factory flash using your VIN# and it includes the orignal immobilizer code. This would essentially be a fresh start! Another option presented to me by GSRboi80 was "You need to find/make a buddy with a mitsu scan unit. You can set whatever immobilizer you want to the ECU and have them program the key to match."
Hope this information can help other
senate6268
Lancer Engine Management / Tuning Forums
703
Dec 5, 2022 02:44 AM
mrfred
Sep 17, 2017 06:11 AM
GrabbinGears
Jul 7, 2016 02:19 PM
racer135
May 24, 2008 07:59 AM
jcsbanks
Feb 11, 2008 11:19 AM
