Installing GM 3 Port Boost Solenoid
Old Dec 4, 2008 | 03:50 PM
RevMoto's Avatar
Originally Posted by rolly1818
my own looks like the one in the Original Post lol...
i think i am really looking into this too much and confusing everyone!!
to clear it up the pigtail has 2 wires! the harness running to the MAF, branches off into two clips with 2 wires each these connect to the OEM boost solenoid.......
damn this is confusing, i need to get some pics!
If you have the one in the picture above then you should just plug it in and splice nothing. If you have a harness the same as the write up that everyone references to then you cut the factory connecter off the stock bcs and splice the new harness to that. What is the difficult part?
Old Dec 4, 2008 | 08:10 PM
Evo8uk's Avatar
I think because he has a JDM model he has the twin solenoid setup which is standard on them and as far as im aware none of the American cars come with the twin boost solenoids.
Old Dec 4, 2008 | 08:45 PM
Vigman's Avatar
Can you take some pictures?
(btw, do not take it as a tip but some grounded chassis stuffs can work with 1 wire only!)
Old Dec 4, 2008 | 11:14 PM
RazorLab's Avatar
If it is a twin solenoid model, I would tap it into the primary solenoid harness, not the secondary passive solenoid. Keep the passive solenoid plugged in though.
Old Dec 6, 2008 | 11:04 AM
rolly1818's Avatar
Registered User
oops should have said before, its a JDM 2006 IX. so it has twin boost solenoid.
sorry for the confusion
thats what i am trying to figure out...which is the primary solenoid?
Old Dec 6, 2008 | 04:23 PM
RoadSpike's Avatar
Not having a JDM to look at here can you check the vacuum lines and see which solenoid runs to the wastegate? Or do both of them run to the wastegate?
Old Dec 8, 2008 | 02:35 AM
rolly1818's Avatar
Registered User
sorry for the late reply, i was out fo the country this weekend so no messing around with the car!
i will try to snap some pics later, for now i am runnin wastegate boost.
i also read that after the GM Boost Solenoid is installed i will need to tune, so i will have to get around to that afterwards.
Old Dec 15, 2008 | 04:46 AM
rolly1818's Avatar
Registered User
Pics Up Help!
Here are the pics. u will see both wires coming off the same harness and the MAF.
note: the clips are removed from the end of the wire!
Old Dec 15, 2008 | 06:05 AM
rolly1818's Avatar
Registered User
ttt
Old Dec 17, 2008 | 12:40 PM
rolly1818's Avatar
Registered User
bump for some help!!!
Old Dec 17, 2008 | 01:09 PM
RoadSpike's Avatar
It would have been a lot easier to help you if you didn't cut off the cables and remove the solenoids. When i get home i'll go through the circuit diagrams and try dicipher the mess.
Old Dec 17, 2008 | 04:42 PM
rolly1818's Avatar
Registered User
Thanks a million, its a long story how the cables got like that.
Old Dec 17, 2008 | 04:45 PM
RoadSpike's Avatar
Just for my own reference what are the color patterns on the wires?
ie: red/white, blue/white
Old Dec 17, 2008 | 06:21 PM
RoadSpike's Avatar
The color codes in my service manual are Red/yellow and light green for the solenoid. I hope that's the only color combination in there.
Old Dec 22, 2008 | 03:52 AM
rolly1818's Avatar
Registered User
sorry bro, was out of the country so could not get access to my vehicle!
i will check and confirm the colors of the wires for you tonight!
Thanks again.
