Installing GM 3 Port Boost Solenoid
Old Dec 22, 2008 | 04:38 AM
  #31
aalzuhair's Avatar
Use the one that had the gray clip on it .. the other one (the black clip) leave it aside
Az
Old Dec 22, 2008 | 04:42 AM
  #32
rolly1818's Avatar
Registered User
LONG STORY both clips are off as you can see in pics (honestly cannot remember which one is where!.. i have to work with wire colours!
Old Dec 22, 2008 | 05:33 AM
  #33
aalzuhair's Avatar
use the one that has the thin green wire
Old Dec 22, 2008 | 06:08 AM
  #34
rolly1818's Avatar
Registered User
simple enough... will ttry later and post pics to suit...
Thanks
Old Dec 31, 2008 | 03:53 PM
  #35
rolly1818's Avatar
Registered User
so was gonna splice on the "green wire" then realized this!
see pics below. two green wire and 2 red wires
Old Dec 31, 2008 | 04:00 PM
  #36
rolly1818's Avatar
Registered User
which do i splice?
Old Jan 2, 2009 | 01:19 PM
  #37
rolly1818's Avatar
Registered User
Bump for help!!!
i need more than wastegate boost!
Old Jan 2, 2009 | 09:42 PM
  #38
RoadSpike's Avatar
Originally Posted by rolly1818
Bump for help!!!
Greens are both grounds it doesn't matter which one you splice.
Old Jan 2, 2009 | 10:40 PM
  #39
rolly1818's Avatar
Registered User
thanks so i can also splice anyone of the red wire as well?
and the other 2 i tape off and thats that?
Old Jan 4, 2009 | 06:53 PM
  #40
rolly1818's Avatar
Registered User
bump for help!
  #41
rolly1818's Avatar
Registered User
bump for help!
Old Jan 4, 2009 | 07:19 PM
  #42
RoadSpike's Avatar
I can't really tell but one of them should be red with a yellow stripe. Unless both of them are that color...
If they are you can just wire tie the solenoid in and test it. A quick goosing of the throttle should make the solenoid click a bit.
Old Jan 5, 2009 | 02:09 AM
  #43
rolly1818's Avatar
Registered User
there is a red wire with a yellow strip...
just to confirm red wire with yellow strip and green wire with yellow strip and splice both onto the Boost Solenoid & Tape off the other 2!
will do and post results.
i also read that when initally hooked up the car should not be driven (at least boosting)?
the next questions is how-to tune lol.
Old Jan 6, 2009 | 03:29 PM
  #44
rolly1818's Avatar
Registered User
bump!
Old Jan 11, 2009 | 01:18 AM
  #45
burgers22's Avatar
Seems like you're going to have to test all possible connections. You will have to connect to one of the wires, hook all the boost pipes up, then adjust the WGDC and BDEL tables and see if they change boost.
MB
