Building to much boost with 2 step
Old Dec 11, 2008 | 05:47 PM
WickedWhtMR's Avatar
You know... I had this same problem when I got tuned. I didnt think anything of it. A couple of months later... i tired to 2step again and it would only build 10 lbs. I thought something was wrong with the car when it stopped building 20lbs. I never did figure out what happened. Ive never been able to build anymore than 10-11lbs since then.
Old Dec 11, 2008 | 08:13 PM
35rEvo's Avatar
Originally Posted by Dsmhater
The point of installing a map sensor is so you can log boost. A map sensor is much more accurate than a mechanical boost gauge and its something I use in all of my cars to tune. I was installing it already but instead of doing that this weekend I am doing it tonight.
Right, but you said while 2 step, the boost builds to 20lbs according to your boost gauge and used to show 8-10psi. Nothing is wrong with the boost gauge so installing the map sensor to log the boost will do what?
Old Dec 11, 2008 | 08:53 PM
DDATuned's Avatar
In a situation like this, it will confirm what is going on. As I already said , mechanical boost gauges are not 100% accurate.
Old Dec 11, 2008 | 09:40 PM
35rEvo's Avatar
Sure they aren't, but they won't show a variance of 10-12 psi if nothing is wrong it.
Old Dec 12, 2008 | 01:03 PM
PeteyTurbo's Avatar
Let me know if you need any help for the 3 bar map sensor..You know it's not something you can just install and have it work, right?
Old Dec 12, 2008 | 01:36 PM
35rEvo's Avatar
Fortunately for dsmhater, he is a former shop owner and has been tuning cars for several years. I am sure he knows this already.
Old Dec 15, 2008 | 05:09 PM
xpro's Avatar
where do you add negative timing for 2step?
intrested
thanks
Old Dec 15, 2008 | 09:02 PM
DDATuned's Avatar
Thanks Petey but I installed and logged the map sensor this past weekend.Boost is back to 10psi at 5500. Logged via ecu+. I am still not sure why or what made the 2 step spike the way it did , but its not doing it anymore.
SWOLN
Oct 15, 2015 11:07 AM
mac11wildcat
Apr 10, 2008 07:24 PM
SPOOLEDTSiAWD
Oct 15, 2007 10:24 PM
GT35REVO8
Mar 25, 2007 11:34 PM
kekek
Feb 27, 2006 08:39 AM
