ECU controlled Window Switch
Old Dec 15, 2008 | 01:54 PM
04gsna's Avatar
Tephra, MRFred This goes out to you guys mostly. I have a Nitrous setup in my car and was trying to find a way to activate this through the ECU. Maybe by using a PINOUT for the intercooler sprayer to activate and spray randomly above a certain threshold.
I am trying to activate my intercooler sprayer which usually needs to be activated for 10 seconds at a time, maybe once every 2 minutes or such. Do you think an idea like this is feasible?
Old Dec 15, 2008 | 03:46 PM
dan l's Avatar
Pin 57 is the IC sprayer relay. I would put a Hobbs pressure switch inline with this for saftey so that nitrous doesen't accidentally turn on without boost and probably put a RPM window switch in line as well so you don't smash your rods by having it turn on at too low of an RPM. If the rpm window switch, hobbs switch, and the IC relay conditions are met, you have nitrous.
Old Dec 15, 2008 | 04:49 PM
04gsna's Avatar
where would this pressure switch be found?
Old Dec 15, 2008 | 04:54 PM
dan l's Avatar
I'm sorry, forget about the rpm window switch. Get a hobbs pressure switch. You can buy one non adjustable or buy one allready set to a certain pressure. mcmastercarr.com sells them, just type in hobbs pressure switch. I would say set it for like 15-20psi if you run 25-30psi of boost. That way the pressure switch has to be made AND the ecu has to set the ground for the output on pin 57 at the ecu. Have give the ground to a relay. Then use the contacts of the relay to turn on the nitrous solenoid and/or fuel solenoid if your running a wet kit.
Old Dec 15, 2008 | 04:58 PM
04gsna's Avatar
thankss so much man, Im just running a intercooler spray bar for this. My wet kit has a TPS control
Old Dec 16, 2008 | 07:35 AM
wreckleford's Avatar
So you are saying the water spray output could be used as a rpm window switch? Is there a current modified ROM that allows it to be controlled by RPM only. I want something like the to engage mivec on a 4g92.
Old Dec 20, 2008 | 11:50 AM
todd6027's Avatar
i certainly hope so
Old Mar 19, 2011 | 10:49 AM
C3L1CA's Avatar
Were you able to get the nitrous to work via the intercooler sprayer pin out?
This sounds like exactly what I want to do but haven't been able to find any solid data on it.
Old Mar 20, 2011 | 10:17 AM
You can do something like this with Tephra's ROMS. I learned this from JOT. Just set the knock required to turn on intercooler water spray to zero and set the load where you want it to come in and use the waterspray output to activate it.
Old Mar 21, 2011 | 06:51 AM
C3L1CA's Avatar
Does it have to be load or can I set it by RPM?
I am looking to wire it up like I had it on my DSM. In DSMLink I wired it to the factory FPR output. It would work between a certain RPM, below a certain amount of knock, above a set MPH. Would it be the best to wire it up to the intercooler sprayer output or best to wire it up to something else?
Old Jun 12, 2011 | 10:59 AM
C3L1CA's Avatar
Any body else have any more recommendations? I'm still a little confuse.
Tmosser
Aug 8, 2012 12:13 AM
lancer586
Lancer Troubleshooting
Jan 27, 2012 01:05 PM
fwd_josh
Sep 10, 2010 02:00 PM
Odenl0ki
Jun 27, 2008 08:20 PM
96_LXR
Jun 9, 2006 06:58 AM
