need Evo 9 owner to test rear O2 *heater* sim patch
Old May 6, 2009 | 10:06 AM
  #226
Jeff_Jeske's Avatar
So WTF..... this isn't one or the other? I was under the impression I could do it Mrfreds in #59 or I could do it the acamus way in #117. If this truely is a combination of both then that is why its not working.
Old May 6, 2009 | 10:27 AM
  #227
travman's Avatar
Acumus's post is for the ready monitors - makes them always "ready" or "complete" so you never worry about failing an OBD-II inspection if your state requires on whether you have all your emissions equipment hooked up or not. So you can disable rear O2, EGR, evap, etc and according to the ecu they will still be there, intact, and pass.
Mrfreds is the rear O2 heater patch so you can eliminate the rear O2 completely with no CEL, as long as you also run the rear O2 sim along with it.
They both work perfect.....but they each do there own thing.
Old May 6, 2009 | 07:18 PM
  #228
Jeff_Jeske's Avatar
Ok... all better. The combination of the two worked like a champ. Thanks to all that held my hand on this one.
Old May 7, 2009 | 05:18 AM
  #229
japanevo's Avatar
glad you got yours working.. i still get a CEL.... this is starting to drive me nuts....
Old May 12, 2009 | 02:02 PM
  #230
logic's Avatar
Just a word of thanks to acamus, mrfred, and quite a few others: my USDM '05 running 96530006 (er, actually 96530706t5) with no cat, rear O2, EGR, or resistor simulator just passed Illinois OBD-II testing without difficulty thanks to a few disabled periphery values and a some adjusted available/passed bits.
Edit: I should point out that it was only good enough to get me through emissions testing; about a mile down the road afterward, I threw a P0125, as expected, since I just disabled the rear O2 check in the periphery to get rid of the CEL long enough for the test to complete. A proper heater simulation/removal would be greatly appreciated for 96530006, but this was certainly good enough to get me past the immediate problem.
Old May 12, 2009 | 05:37 PM
  #231
mt057's Avatar
So I have read both threads and I still am a little confused about how to disable the rear o2 heater. Can I simply use Amacus's patch to remove cel/pass emissions for the rear o2 heater (I am running the o2 sim) or do I need to use both Mr. Fred's and Amacus's patches. I am attempting to do it on the 94170015 rom. Thank you for your help.
Old May 12, 2009 | 07:24 PM
  #232
Jeff_Jeske's Avatar
Mrfred's patch trick *** the computer into thinking the O2 is there when its not.
Amacus's patch trick *** the computer into sending "pass" result when queried.
They work together but the Amacus patch is not required unless you get tested.
Old May 12, 2009 | 07:59 PM
  #233
mt057's Avatar
how do you simulate the o2 heater for the 94170015 rom? I can find it for the evo9 roms but not for the 8. Please help
Old May 13, 2009 | 03:31 PM
  #234
Wiznaz's Avatar
Jeff Jeske I found that you still need to enable Tephra's 5.1 mod to disable any related O2 codes as well.
Old May 14, 2009 | 07:08 PM
  #235
Jeff_Jeske's Avatar
^ You are correct.
Old May 16, 2009 | 09:10 PM
  #236
logic's Avatar
Originally Posted by mrfred
Sorry for taking so long to get this posted. A *stock* patched 88590015 ROM and the accompanying xml definitions are in the link below.
I spent a bit of time tonight looking at your changes to 88590015, and started poking at 96530006 to see if this would be straightforward to port to the VIII ROMs. It took me a bit of time to find it, because I'm slow like that, but it looks like the subroutine you replaced at 0x44C10 in 88590015 lives at 0x2F9C0 in 96530006 (the jump table reference in 8859 at 0x2DC50 appears to be at 0x2C7A4 in 9653).
Comparing the original subroutine (not your modified version) in 88590015 to the one in 96530006, there appears to be a bit of difference between the VIII and IX code, although I haven't done an in-depth comparison yet. So before I get into this any further: did you ever port this over to a non-IX ROM, and I just missed the post? Or, would we be able to tempt you to dig into it just a little bit?
Also, it looks like nothing between 0x2F9C0 through 0x2FD49 (and the same chunk of subroutines in 8859) is referenced anywhere but as part of the heater circuit code; unless I'm missing something obvious, couldn't you yank the entire block of code, replace it with your (much shorter) sim, and use the remaining space for "other code"? Did you keep the old code around because it gets called from somewhere I'm missing, or was it just for safety/ease of reverting back?
tephra: do you still have plans to integrate this into a future release, if the details get worked out?
Old May 16, 2009 | 09:12 PM
  #237
tephra's Avatar
if you want it integrated into V7 then i need to know exactly how it works...
does it disable the heating function - ie if you install it onto a car WITH a rear02 will it break anything?
Old May 16, 2009 | 09:19 PM
  #238
logic's Avatar
I don't believe this affects anything but the readiness testing for the heater circuit, but I'd have to defer to mrfred and acamus for a definitive answer. (I might be able to mash the keys, but it doesn't necessarily mean I know what I'm typing. )
Old May 19, 2009 | 08:33 AM
  #239
logic's Avatar
You know, I'm looking at the code for 96530006 and comparing it to 88590015:
For 96530006:
Code:
loc_2C61E:                               ! CODE XREF: sub_2C55C+48
                 mov.l   @(0x1CC,pc), r0 ! [0002C7EC] = MUT_D3
                 mov.w   @r0, r0
                 shlr8   r0
                 tst     #8, r0
                 bt      loc_2C62E
                 mov.l   @(0x178,pc), r10 ! [0002C7A4] = sub_2F9C0
                 jsr     @r10 ! sub_2F9C0
                 nop
For 88590015:
Code:
loc_2DAF4:                               ! CODE XREF: sub_2C4F0+15E6
                                         ! sub_2C4F0+15F8
                 mov.l   @(0x154,pc), r0 ! [0002DC4C] = 0xFFFF6BB8
                 mov.w   @r0, r0
                 shlr8   r0
                 tst     #8, r0
                 bt      loc_2DB08
                 mov.l   @(0x154,pc), r4 ! [0002DC54] = unk_9DE0
                 mov     #1, r5
                 mov.l   @(0x14C,pc), r10 ! [0002DC50] = sub_47E30
                 jsr     @r10 ! sub_47E30
                 nop
Assuming you already have acamus' readiness patch in place, is there any reason that these whole routines couldn't just be replaced with NOPs? That would effectively prevent the test from running, the same as setting FCA #8 (bit 3) to 0 would, but without the side effect of disabling all the other tests wrapped with that same periphery bit.
For a more refined approach, you could replace the MUT_D3 #8 comparison with a comparison to another location, to make it a toggle of it's own. (I'm thinking a "tephramod option" here. )
I may give this a try at lunch today, and see if the simple approach is "good enough".
Old May 19, 2009 | 10:51 AM
  #240
fostytou's Avatar
EvoM Community Team
As far as I understand it, MrFred's code just essentially clears the CEL when inside the parameters for it to occur.
