Unable to read ECU?
Old Feb 23, 2009 | 10:16 PM
worksevo89's Avatar
Registered User
Question Unable to read ECU?
So im just trying to get started at this whole tuning thing, and so far its going bad. Everytime I try to read the ROM off my car it says unable to connect.
I plug in the cable, the opinion to read becomes available, then I choose me car on the list and it starts load and then says unable to connect.
What am I doing wrong?
Old Feb 23, 2009 | 10:22 PM
Sean@Iveytune's Avatar
Call Works and tell them what you are trying to do.
Sean
Old Feb 23, 2009 | 10:27 PM
worksevo89's Avatar
Registered User
Why? Is it because of the Works Flash that I cant access my ecu?
Old Feb 24, 2009 | 12:56 PM
kreionic's Avatar
Yes they may have locked it
Old Feb 24, 2009 | 01:03 PM
travman's Avatar
Yeah probably - some change the init code and you have to run an unlocker tool with ecuflash to access it.
Another thing is if your battery voltage is low it can cause issues for reading/writing.......trying driving the car for a bit then try and read from the ecu.
Old Feb 24, 2009 | 01:38 PM
baylorar's Avatar
Wow, that's pretty weak on Works behalf if they locked his ECU just because they flashed the car.
Old Feb 24, 2009 | 01:59 PM
Fast_Freddie's Avatar
Veteran: Navy
^ not really... its called job assurance...
Old Feb 24, 2009 | 02:05 PM
worksevo89's Avatar
Registered User
Thanks guys Ill give them a call.
Old Feb 24, 2009 | 05:46 PM
Courtesy locked or not call them. They will advise you perhaps you need to send the ecu back.
Sean
Old Feb 24, 2009 | 06:30 PM
baylorar's Avatar
I think that makes no sense, but that's just me.
Old Feb 25, 2009 | 08:42 AM
8awd-dreamz's Avatar
yea mine read the ecu once, then i tried to reflash then it said error see log,, then when i tried to read it again it wouldnt read my ecu
Burnhad91
Nov 10, 2015 02:43 PM
ghost4g63
Sep 21, 2009 06:08 AM
xspsi4
Aug 19, 2009 10:42 PM
lan_evo_mr9
Nov 1, 2008 02:09 PM
honki24
Aug 11, 2006 11:53 AM
