TephraMOD V6 - testing!
Old Apr 17, 2009 | 03:06 AM
  #481
tephra's Avatar
yeah I reckon...
so far the list of ROMID's that I will be doing are:
96530006
96260009
90550001
88570008
maybe 88580014
maybe 88590015
maybe 88840017
the 3 maybes are really if 88570008 can run them instead
anyways - I am hoping to hear back from some more testers on 96530006 V7T1...? anyone got any good+bad to report?
Old Apr 17, 2009 | 06:12 AM
  #482
Danieln's Avatar
Originally Posted by tephra
well I am hoping someone will test 88570008 over the top of 88590015.
I think john said it worked the other way... would mean 1 less rom todo.
Hi Dave,
This morning I try this by coincidence on a 88580015 IX RS JDM.
I was curious if this Rom will work but the car did not start......as I figured
Two different maps I try to see what will happens....
Old Apr 17, 2009 | 06:29 AM
  #483
travman's Avatar
Originally Posted by Danieln
Hi Dave,
Probably due to the immobilizer - did you disable it?
Old Apr 17, 2009 | 08:39 AM
  #484
Danieln's Avatar
I did that mate nut with no result.
I miss something for sure but not the immobilizer code or how to flash it.
I hope one day we will use all of us the same rom-id witch can be developt by all the great beautiful minds around here.
And please take it like a compliment....
Old Apr 17, 2009 | 01:13 PM
  #485
dan l's Avatar
Tephra,
I had something weird happen today running on v6. I threw a P0181 code pulling out of my parking spot. That is for the Fuel Temperature Sensor. I am running a MAT air temperature. Does the V6 rom use mfreds sim for the fuel temp sensor?
Old Apr 17, 2009 | 01:19 PM
  #486
fixem2's Avatar
For the new gear based boost control, is there still a boost adder table and is the gear based table limited to 24.6?
I ask this because I saw a screen shot of frostyou's boost maps and I thought he had 27.x in the table.
Old Apr 17, 2009 | 01:47 PM
  #487
fostytou's Avatar
EvoM Community Team
I have rescaled my ecuflash calcs to account for boost adder - absolute pressure. Direct boost control is still a mod separate from the tephra mods (as it should be since not everyone uses it). It just makes it easier for me to tune since sometimes I'm more forgetful than I'd like to be.
see here for more info (and a few posts down)
https://www.evolutionm.net/forums/6778192-post592.html
Old Apr 17, 2009 | 06:03 PM
  #488
Vigman's Avatar
yeah I reckon...
maybe 88590015
I really hope that 88590015 will exist :-)
Thanx Tephra, your work is amazing anyway!
Old Apr 17, 2009 | 06:23 PM
  #489
phenem's Avatar
OK a couple weird things, when I first start the car it idles like crazy high, around 2000 RPM. Tried this on the stock 9653 and it does the exact same thing so I don't think it v7 related. Then it settles down to where it should be. It then threw a code: P0505
I changed the idle and bumped it up, thinking it would not idle that low (stock settings) but it still throws a code: P0505
It still idles crazy high when cold no matter what I change, when warm it starts up and settles down no problem.
Changed all values back to stock and it still idles really high on cold start, but then settles down, but it still threw a code.
Any idea if it's related? No problem at all on my 9417 map....I switched back to make sure, no code, no idle problems at all.
The only other thing that I changed that might have something to do with this is the Cranking Enrichment IPW Adder (not the alternate, the factory one) the definition I use for this is:
Code:
    <table name="Cranking Enrichment IPW Adder (Main)" address="58d0" category="Fuel" type="2D" scaling="TimeInjCranking">
	<table name="Coolant Temperature" address="69d8" type="Y Axis" elements="9" scaling="Temp"/>
    </table>
Is that correct table for the stock Cranking IPW table?
~Zach
Old Apr 17, 2009 | 06:34 PM
  #490
l2r99gst's Avatar
P0505 should be fixed by setting your BISS. Use the Evoscan actuator, then set the BISS to your idle.
Old Apr 17, 2009 | 06:41 PM
  #491
phenem's Avatar
Can you explain this more. I know the BISS is that little screw in the throttle body, how to I use EVOScan?
~Zach
Old Apr 17, 2009 | 06:47 PM
  #492
l2r99gst's Avatar
On the bottom right side of Evoscan there is an actuators section. The last one in the list is 'Speed Adj. Screw mode'. If you activate that, it parks your ISC to a certain value (I forgot which value off the top of my head). Click activate and then unscrew your BISS until your car will idle at your desired RPM while activated.
Then, deactivate the 'Speed Adj Screw mode' actuator. Your idle will shoot up high when you do this and will take a bit to come down to normal as the ISC is slow in adjusting downwards (I just found this out the other day). But after so many minutes, your idle should be at the desired value and you won't get the P0505 because the ISC won't be at it's extreme to try to maintain your idle.
Note: The first time you activate the SAS mode, your car will most likely stumble and almost die. Get ready to start slowly unscrewing the BISS.
Old Apr 17, 2009 | 06:56 PM
  #493
tephra's Avatar
that def for cranking enrichment is good zach.
I hope someone updates the 96530006 def in ecuflash with the best/newest defs
Eric - right on with the BISS.
P0505 = idle motor having to work outside its normal operating parameters, ie base idle is incorrectly set...
  #494
phenem's Avatar
Great! Thanks man, I will give it a shot tomorrow. Appreciate the help
~Zach
Old Apr 17, 2009 | 07:06 PM
  #495
phenem's Avatar
I have found all the important tables needed (I think) so I can provide you with everything in an XML, that's if you want to incorporate anything with your V7 mods....
~Zach
