TephraMOD V6 - testing!
Old Apr 22, 2009 | 07:53 PM
  #526
nano's Avatar
I've read through this post multiple times, and just can't seem to figure out why this isn't working properly...
I run a JDM MAP sensor along with the direct boost control. Both mods have been configured correctly, I double checked all the setting changes etc.
I changed the scaling on the "Boost Desired Engine Load" to psi8 and put in my correct values.....is this correct?
When I log, BoostError stays at -3.087 no matter how much I boost, I never see any change in WGDC, it stays 0. This is with the updated definitions for EvoScan on the front page. I can boost maybe ~11psi and thats it. In my tables I have 21psi.
My WGDC=100% under this load is set to 100 atm, I also flashed with 200 (stock value) with no changes. all other settings are kept the exact same and this is the 88590615 id.
Any help is greatly appreciated!
--Tom
Old Apr 22, 2009 | 08:00 PM
  #527
tephra's Avatar
Tom - which BDEL table did you modify the scaling on?
the original table OR the new 3d table?
you NEED to change the scaling on the new 3d table (and put proper numbers in too)
Old Apr 22, 2009 | 08:08 PM
  #528
nano's Avatar
I have attached what I have for scalings and the 3d map. Do I have to account for the Boost Adder or does it calculate it with the 3d map aswell?
Thanks for the quick response tephra.
Old Apr 22, 2009 | 08:57 PM
  #529
tephra's Avatar
yeah that looks ok.
You need to still do the Boost Adder as well...
Old Apr 22, 2009 | 08:58 PM
  #530
nano's Avatar
Yep, I have it set to 14.7....I have no idea why it's not working properly :-\ I will test it tomorrow once again.
Old Apr 22, 2009 | 09:01 PM
  #531
tephra's Avatar
oh hold on.
what do you have your WGDC tables set to?
Old Apr 22, 2009 | 09:24 PM
  #532
nano's Avatar
Attached
Old Apr 22, 2009 | 09:26 PM
  #533
tephra's Avatar
that should be working.
can you post a snippet of the log?
Old Apr 22, 2009 | 09:38 PM
  #534
nano's Avatar
This is the only log I got cause I just stopped logging and went straight back to the computer to find a problem, even though I'm not flooring it -- it should of still pulled WGDC, and it doesnt show anything.
Tomorrow I can post a log of a 100% TPS pull in 3rd or 4th.
Thanks again for the help with this You seem to offer better support than Dell LOL
Old Apr 22, 2009 | 09:41 PM
  #535
tephra's Avatar
1) i would adjust your rpm_speed/gear table so its not jumping between 5/6 gear...
2) regardless of correction you should be getting your WGDC from the map - so it should read something other than 0
hrmm this is def V6 yeah?
Old Apr 22, 2009 | 09:44 PM
  #536
nano's Avatar
Yes v6 is the only one I downloaded, TephraMOD-88590615 confirmed.
And I agree I just haven't really had a chance to sit down and test it.
Old Apr 22, 2009 | 09:45 PM
  #537
tephra's Avatar
your not on altmaps are you?
Old Apr 22, 2009 | 09:46 PM
  #538
nano's Avatar
Nope, never have been and I don't have the harness either.
Old Apr 22, 2009 | 09:47 PM
  #539
tephra's Avatar
just copy your wgdc table to your altmap version - maybe I got the labelling around the wrong way ? :P
Old Apr 22, 2009 | 09:50 PM
  #540
nano's Avatar
Will try it and report back most likely tmrw morning. Thanks again for all your help I appreciate it greatly.
