TephraMOD V6 - testing!
Old May 12, 2009 | 02:51 PM
  #736
Oracle1's Avatar
Dave - off topic sorry - Will the new version have 3 map switch or shall I add a BCS switch instead?
Old May 12, 2009 | 04:50 PM
  #737
tephra's Avatar
what do u mean?
v7 still only has 2 maps (normal and altmap) cant really call launchmaps a map
Old May 12, 2009 | 05:45 PM
  #738
tom04841's Avatar
Originally Posted by tom04841
I will give 9563 v5.10 a shot and post up results.
Well i gave another shot at v7.5 and have a better log. It did the same thing as last time, but i held it longer and at wot. Here is the link. http://www.mediafire.com/?sharekey=a...4e75f6e8ebb871
When You look at the part of the log where I am wot, you can see that my rpms don't climb over 3500.
And just for the hell of it, I flashed v5.10. Took it for a spin and it ran perfect.....I don't understand
Old May 12, 2009 | 07:53 PM
  #739
the_mork's Avatar
I still can't read your load for some reason even though I've switched to 1byte load now and it works fine reading my logs.
Except for your quick spike it looks like you are bouncing off a rev limiter. What is your NLTS set at? Are you an automatic or a manual? What about stationary rev limit? Would you check your moving rev limit just for ****s and giggles? If you are a manual try pulling the wires on your clutch switch(es) and/or changing the rev limit for NLTS.
I have an automatic and I have also turned off NLTS, I have no idea what sort of behavior I might witness if it wasn't off.
Old May 12, 2009 | 08:13 PM
  #740
tom04841's Avatar
nlts is disabled. I am manual. stationary is at 5000, moving is 7600. My clutch switches arent hooked up
Old May 13, 2009 | 05:38 PM
  #741
nothere's Avatar
Originally Posted by TTP Engineering
This is what I have gathered. No EGR and MAP sensor, however. It appears that we get idle control code p0505 with this rom. I have changed IAC valve and it still throws it. Will look at the settings one more time on monday just to be sure.
how about it guys is p0505 involved in t706?
Old May 13, 2009 | 05:42 PM
  #742
TTP Engineering's Avatar
I still get p0505 regardless of idle settings. There is something not right with the euro map on usdm IAC wiring IMO.
Old May 13, 2009 | 05:47 PM
  #743
phenem's Avatar
I was getting the P0505 code, I set my idle screw and everything and still got it.
Since then I have set Periphery2, bit 08 (idle test) to 0 and haven't seen that code come up yet. I haven't driven the car a lot (about 10 miles) but I still haven't gotten the code....
Old May 13, 2009 | 05:48 PM
  #744
l2r99gst's Avatar
Sorry if you have mentioned it already, but have you set the BISS using the SAS mode in EvoScan? I have been using the 96530006 ROM in place of 96940011 and never threw a cel with it.
Old May 13, 2009 | 05:49 PM
  #745
phenem's Avatar
Can you try setting the Periphery2, bit 08 (idle test) to 0 and see what happens?
Old May 13, 2009 | 05:50 PM
  #746
phenem's Avatar
He said he has and I have as well.....I have set the BISS using SAS mode multiple times and get it every time.....
Now that I have the Periphery bit set I have not gotten it yet....
Old May 13, 2009 | 05:55 PM
  #747
l2r99gst's Avatar
That's interesting then. Wonder why some have the issue and some don't then.
What about the other ISCV tables and idle tables? Did you copy them from your old ROM or leave the stock 9653 tables in place. I left the stock 9653 tables in there. Maybe that has something to do with it?
Anyway, using the periphery bit you mentioned should keep the cel from coming on, but I'm still curious why the cel only comes on for some people.
Old May 13, 2009 | 05:58 PM
  #748
phenem's Avatar
Left the tables bone stock else I would have weird idle issues.....left them stock and got the p0505 but that was better than the car not idling correctly.
Now that I have set the periphery set I hope the code stays away.....
Old May 13, 2009 | 06:01 PM
  #749
tephra's Avatar
can you log ISCSteps and see what happens when you get the CEL?
You shouldn't be getting the CEL.
Eric what did you set your base idle to?
Old May 13, 2009 | 06:05 PM
  #750
l2r99gst's Avatar
Actually, when I adjusted the BISS, I forgot that the ISCSteps take a long time to adjust downwards, so I actually adjusted the BISS so that idle was below my target idle. I forget the exact number I used.
I think my idle in my ECU is set at 850 or 900 (have to check my ROM). I actually set the BISS slightly lower than that. I was going to fix it up to my ECU value, but it drives fine, doesn't throw a CEL, so I left it as is. I did adjust it to be higher than it was (almost stalling in SAS mode).
