JDM Map values
Old Feb 26, 2009 | 01:26 PM
evovette's Avatar
JDM Map values
I was wondering if anyone had the voltage readings for the JDM map sensor. I.E. 1 volt = 14 psi etc etc. Reason I ask is Im trying to get a digital gauge made up to display boost directly from the map sensor to help clean up the clutter under the hood. I was speaking with the guys at Dynotune today and was told if I had the voltages they would most likely be able to make a gauge for me. Any help would be great.
Old Feb 26, 2009 | 02:31 PM
fostytou's Avatar
EvoM Community Team
You can find some assumption based "answers" here:
https://www.evolutionm.net/forums/6715310-post100.html
It would probably be better to just test it though. How are you going to tap the signal without interfering with what is sent to the ECU?
Old Feb 26, 2009 | 03:53 PM
evovette's Avatar
would it really be all that bad to just tap the stock wire at the ecu ? I wonder how it would make performance suffer?
mrfred
Sep 17, 2017 06:11 AM
Raceghost
Jun 21, 2016 12:40 PM
YaroRS
Apr 15, 2011 07:36 AM
daisaw1219
Apr 13, 2010 06:31 PM
mchuang
Mar 12, 2008 06:19 PM
