ECUFlash Error
Old Mar 21, 2009 | 04:02 PM
JordanS4's Avatar
Originally Posted by voidhawk
Your ECU has been locked by a previous tuner - this is usually done by changing the "Init Code" field in the ECU map. Download the “ECU Unlocker” add-on from AktiveMatrix (www.aktivematrix.com). To download files you have to register, then go to the download section and look for “Mitsubishi ECU Unlocker 1.1 for ECUFlash”. When you download the file, it has no extension, but it is a compressed zip file. Add the extension and unzip it. The current version requires the Microsoft .Net framework v2.0 (or higher) which you can get from “Windows Update”. If everything works, you can double-click on the executable and a small window pops up telling you to leave the program running and startup ECUFlash. Now start ECUFlash and it should connect just fine.
Are you sure? I know my tuner wouldn't do that, and I used my friends laptop and his ECUFlash as well as my cable to access and flash my ECU.
Old Mar 21, 2009 | 04:04 PM
voidhawk's Avatar
try it and see if it works - can't hurt it.
Old Mar 21, 2009 | 04:11 PM
JordanS4's Avatar
windows version works now, didn't DL ECU Unlocker though.
NightHawk
Jun 8, 2015 06:28 PM
gilbertflores
Oct 13, 2008 05:34 PM
PibusEVO
Apr 2, 2008 08:34 AM
ggevoIX
Mar 27, 2008 06:21 PM
