Immoiliser disable with openport 1.3
Old Mar 19, 2009 | 11:00 AM
itacool's Avatar
Hello!
I hope that i'm posting it in the right forum.
I have installed evo7 engine in a mitsubishi colt , and i use the stock ecu of this engine (MR560648). The engine dont start and as i belive the problem is the original immobiliser . I want to disable the immobiliser and i have seen that i need Tactrix OpenPort 2.0 for connecting to the ecu .I want to build myself the cable and the only schema that i found is for openport 1.3.
Can i use the OpenPort 1.3 for connecting to the ecu and disable the immobiliser?
Thanks!
Old Mar 19, 2009 | 07:37 PM
eastxcelerate's Avatar
+1 for me. I would like to use 96530006 for my 96940011 tephra patch and I need to know how to disable the immobilizer as well. Ofcourse I would rather keep it but just incase.
Old Mar 20, 2009 | 06:30 AM
the_mork's Avatar
I'm not sure about the evo7 ecu for the original poster but in response to the second poster your can add this to the roms metadata.
<table name="(periphery 0)" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
Then you need to change the value of Periphery 0 in ecuflash to 0x56D2. Hopefully this works in an evo7 rom as well, but I am sure that it works in all 8/9 roms.
This will completely disable the immobilizer and there are some other values besides 56D2 which can disable certain o2 sensor functionality.
56D0 -No rear O2 no Immobilizer
5650-no rear O2, No immobilizer, No knock
5658-no rear O2, No knock sensor
56D8-no rear O2
5698, no front or rear 02
5690, no front 02, rear 02, or immobilizer
56D2, No immobilizer
Old Mar 20, 2009 | 07:27 AM
Where in roms metadata do I add this? at the very end or somewhere in the middle? Thank you
Old Mar 20, 2009 | 09:08 AM
rolly1818's Avatar
Registered User
end right before the last line...
Old Mar 20, 2009 | 09:22 AM
the_mork's Avatar
just before </rom>. The placement isn't important as long as it isn't in the middle of something else.
Old Mar 20, 2009 | 08:13 PM
Alright, thanks guys. Hopefully this work with the OP as well. Thanks again.
Old Mar 21, 2009 | 04:52 PM
todd6027's Avatar
56d0 they dont have rear o2 evo7 , use 90550001 rom.
AngelPowy
Dec 6, 2015 07:40 AM
Smalls
Aug 9, 2014 02:38 PM
kubaolong
Sep 12, 2013 07:23 PM
damoevo8
Australian Forum
Jan 10, 2013 04:22 PM
bsh
Nov 23, 2012 01:11 PM
