FP Red is FUN
Old Mar 25, 2009 | 10:45 AM
RoadSpike's Avatar
Originally Posted by jcsbanks
The only Red I've tuned has failed. Warranty inspection awaited. Lots of people reporting FP Green and now Red failures in the UK, not clear why it is happening, there are not the same number of stories about stock turbos and GT3x tuned by the same people in the same way. I thought it wouldn't happen especially since I didn't push it hard.
I liked how it drove except for the surge before 4000 RPM in high gears, which stopped me getting one for my own engine.
I've heard the failures are caused by the stock oil lines not being adequate enough. I may have to contact FP and see what they suggest.
Old Mar 25, 2009 | 12:57 PM
andrewzaragoza's Avatar
I hope they fix this reliability issue since it is a very good turbo.
Old Mar 25, 2009 | 01:27 PM
RoadSpike's Avatar
Trying to contact FP now about the concerns I've went ahead and purchased the upgraded oil line from them. I'll ask them to cancel if it this is not the issue.
I'm posting a log of an up hill run (on ramp) in 3rd gear to show how even a little timing can cause big knock lol! I did get some timing added back into the lower ranges as i expected but I'm slightly disappointed i couldn't add much more on the top end.
Still a work in progress btw for all those benchmark warriors out there.
Old Mar 25, 2009 | 01:46 PM
jcsbanks's Avatar
From 7000 miles away I can hear the engine begging you for octane!
Old Mar 25, 2009 | 01:49 PM
RoadSpike's Avatar
Oh I know that already
Old Mar 25, 2009 | 01:56 PM
rolly1818's Avatar
Registered User
X 2! can you say q16?
what is Load Error? what does that parameter do?
Old Mar 25, 2009 | 02:01 PM
RoadSpike's Avatar
Thats the turbo boost correction since i'm using load based boost control. It tells you what cell its in on the turbo boost correction table.
Old Mar 25, 2009 | 02:06 PM
rolly1818's Avatar
Registered User
wow didn't know that, i use load based control to ..... thanks
i am thinking of the switch to direct though, just trying to justify the need for it.
Old Mar 25, 2009 | 04:42 PM
raasfaas's Avatar
Originally Posted by RoadSpike
I'm not sure how you could have run 8 degrees timing at peak torque anything higher than 3-5 degrees here and it would knock up a storm on the stock turbo. I was running similiar boost to you during those times as well.
The VIII's are able to run more timing than the IX's
Old Mar 25, 2009 | 06:05 PM
RoadSpike's Avatar
Perhaps that is generally true but this car definitely will not at least not with this fuel.
Old Mar 25, 2009 | 06:34 PM
Daryl Nilsen's Avatar
Do you know what failed on the turbo?
Old Mar 25, 2009 | 06:50 PM
RoadSpike's Avatar
On a side note i'm not getting surge here even in 4th gear starting at 3500rpm
Old Mar 25, 2009 | 06:51 PM
raasfaas's Avatar
Don't worry bro I know exactly what you mean, I'm actually worse off than you are...I live in Jamaica where we have 90 octane **** water
Old Mar 25, 2009 | 06:54 PM
RoadSpike's Avatar
Its all good despite the cars lack of timing its still making good power compared to stock. The lag is there but not really as dramatic as i was expecting
Old Mar 25, 2009 | 09:43 PM
G20's Avatar
G20
Originally Posted by spdracr
haha i was laughing no offense just because i prefer adding timing as opposed to boost on my VIII turbo and my car likes timing much more. 8* peak timing on 23 psi im at 15-16* peak timing at 18.5psi at redline. on same **** gas you have. and with absolutely no knock wat so ever. just spend some more time tuning that beast. im sure you'll get it fast as hell soon enough or just run some meth or join E85 crew im still debating since i picked up a IX turbo today haha
how you get 8* timing at peak 23 psi? The best I could do on my 05 is 4-5* at 23.5-24 psi peak boost and gradually increasing to 13* at 7000+ RPM with boost tapped to 19.9-20 psi (yes! for some reason my car hold boost with the MBC) before it starts knocking. This is on 91 oct as well.
To the OP, it looks like the red is holding more boost up top than the stock turbo and that may causing 5-9 knock count starting from 6500. Maybe lower boost a little bit will help get rid of that in order for you to bump up some timings.
