Live mapping and/or speed density instructions
Old Feb 3, 2010 | 01:00 AM
ziad's Avatar
yep it is.... u can try the one off http://www.mztec.org/evo/livemap/ or if u can wait for a few more days (i have one very very strange bug) and i will have a better and more robust version up.... also the one there currently does not like SD tables.
Old Feb 3, 2010 | 01:50 AM
project_skyline's Avatar
Ok well im running the MAF version anyway.
Old Feb 3, 2010 | 03:05 AM
ziad's Avatar
hmm then send me a pm with ur email... might was well get u hooked on the better version.
EDIT: actually check the link i have the latest version that actually works with SD based roms. by default it comes with xml defs for 9653 V7 based roms... i will check add more later or you can add custom ones urself.
Old Feb 3, 2010 | 09:28 AM
SyZyGy1394's Avatar
So if at all possible, what would I have to do to incorporate livemap/dma on 88590715 that I also already patched SD on? Same code, just different addresses? I'd love to know because this would make tuning my light load and cruise areas so much less of a headache.
Old Feb 3, 2010 | 01:39 PM
ziad's Avatar
if u r using V7 then currently no DMA on it.... V5.10 had just search for that rom. in the setting menu of the program you can create new version xml
Old Feb 3, 2010 | 01:44 PM
SyZyGy1394's Avatar
I did find the link to it from jcsbanks, but apparently the link doesn't work. I imagine he isn't sharing it anymore...
I'd be happy with just livemap for now.
Old Feb 3, 2010 | 03:27 PM
ziad's Avatar
i put the rom on my page... will do the others rom if needed.
Old Feb 4, 2010 | 02:16 PM
Ok so in your instructions after it says open the settings and goto create, I pick the old live map directory. I want the xml directory for that correct? It loads the MUT table. What and how exactly do I load the fuel and timing tables?
Im just trying to figure everyone thing out because no offense intended but the directions are kinda vague and short. Only someone who knows what they are doing like you might understand them not someone who is a new user.
Old Feb 4, 2010 | 03:56 PM
l2r99gst's Avatar
Here is how mine is setup. I'll explain each screenshot below the image:
This is where you setup the requests that you want to log. In my screenshot above, this is how I have my RAM MUT table setup for the time being. Simply setup your table to match what you are logging.
On the ECU Definition tab, on the top is where you set the addresses for the start of the ROM and RAM alt maps space and the size.
The entries on the left are the tables that you have setup in the alt maps space to be copied to RAM. In the screenshot above, you can see the address for my RAM MUT table, which is FFFF A000 (which is right at the start of the alt maps space).
You don't necessarily need the MUT table entry here. These entries are just for the tables that you want to tune in RAM. Each of the table entries here will become a new tab in the LiveMap app, so that you can change the values and tune them realtime. The next few screenshots will show how the rest of my tables are configured.
Bigmaps fuel. My axes may be different than yours. I have mine go to 500 load, incremented by 20 after 100 load, and 11000RPM, incremented by 500 through the whole table.
Ignition table. Same axes as fuel.
BWG table
Also, make sure in your settings.xml file, you have the following line setup for DMA:
<transProtocol>DMA</transProtocol>
continued in next post (5 attachment max per post)...
Attached Thumbnails Live mapping and/or speed density instructions-requests.jpg   Live mapping and/or speed density instructions-ecudef-mut.jpg   Live mapping and/or speed density instructions-ecudef-fuel.jpg   Live mapping and/or speed density instructions-ecudef-ign.jpg   Live mapping and/or speed density instructions-ecudef-bwg.jpg
Old Feb 4, 2010 | 04:10 PM
ziad's Avatar
lol.. yeah those are not really instructions... just a cpl grabs from msn conversations. i will do a instruction doco with screen grabs soon. anyway add the table xmls (add table button)... i recomend fuel first... so basically add "fuel.xml" "ignition.xml" and any others u might have.
if u running 9653 V7 or 8859 V510 then use the given XMLs.
i will create a new thread for livemap issues if u want...seeing quite a few downloads have taken place.
EDIT: just check this thread.
https://www.evolutionm.net/forums/ec...e-map-app.html
Old Feb 4, 2010 | 04:20 PM
l2r99gst's Avatar
Continued from two posts above. ziad got a post in between.
BDE Load
RPM VE
Map kPa
Map VE
Injector size
Attached Thumbnails Live mapping and/or speed density instructions-ecudef-bde.jpg   Live mapping and/or speed density instructions-ecudef-rpmve.jpg   Live mapping and/or speed density instructions-ecudef-mapkpa.jpg   Live mapping and/or speed density instructions-ecudef-mapve.jpg   Live mapping and/or speed density instructions-ecudef-injsize.jpg
Old Feb 4, 2010 | 04:26 PM
l2r99gst's Avatar
So, here you can see the main screen and the tabs for all of the RAM tables. Here is a shot of the blank fuel table (my laptop isn't connected to the car at the moment...just here on my desk).
If you have the active cell and knock trace selected in the 'basic settings' tab of the settings window, then when you click start, you get a realtime trace through the table. I forget already, but I think just for the ignition table. The cells will color green for no knock and get darker red with more knock.
Eric
Attached Thumbnails Live mapping and/or speed density instructions-main.jpg
Old Feb 4, 2010 | 04:57 PM
ziad's Avatar
umm can we please move this to the other thread...... that way i can keep track of any info and help me doing the doco.
Rasperin
May 18, 2017 07:56 AM
EvoXCa
Evo X How Tos / Installations
Jun 28, 2016 07:11 PM
Sharpie0311
17
Sep 18, 2014 12:23 PM
lancerguy0208
May 4, 2010 02:55 PM
koach
Apr 4, 2010 02:15 AM
