evoscan cable question
Old May 6, 2009 | 08:56 PM
555R's Avatar
how can i tell what cable i have for evoscan
does anyone have pictures of the pin side of the larger plug?
how many pins are the ecuflash capable cables
if memory serves me right mine has 6 pins but i have to look at it again
i want to load the maps that were saved in the ecu
let me know
thanks
Old May 7, 2009 | 07:59 PM
555R's Avatar
anyone?
Old May 7, 2009 | 08:00 PM
555R's Avatar
6 pins
4 up top and 2 on the bottom
Old May 7, 2009 | 08:03 PM
555R's Avatar
- is no pin
+ has a pin
any ideas if this is ecuflash capable
Old May 7, 2009 | 09:03 PM
Deepnine's Avatar
it does not only depend on the pins. Its the hardware inside the cable that is important.
you need an openport 1.3 or 2.0 cable.
my cable has only 5 pins and works.
Old May 7, 2009 | 09:24 PM
555R's Avatar
if im not mistaken it is a tactrix cable
but for some reason i cant get it to read the ecu
im going to try the ecu unlocker tomorrow
too much rain here so im not going to do any logging until it clears up
Old May 8, 2009 | 08:08 AM
fostytou's Avatar
EvoM Community Team
There are pictures on the main evoscan page......
Old May 8, 2009 | 02:24 PM
555R's Avatar
the pictures dont show the pin configurations
the calbe looks like all of those
Old May 8, 2009 | 03:04 PM
555R's Avatar
pic of the cable
Old May 8, 2009 | 04:23 PM
SoCal Rally's Avatar
Did you plug both the black connector and the white connector in (i.e. not just the black connector)?
Old May 8, 2009 | 04:35 PM
I think you have an earlier version of the cable, since on mine:
- my black OBDII connector has 7 pins (two more on the left, one at the very bottom, one more two pins up from that, but missing the one on the right at the bottom compared to your pic)
- my white programming connector has 3 pins attached
- my white programmin connector is T'd off the same cable as the OBDII port connector and doesn't have the red terminal connector shown in your picture attached to the white connector (I think maybe this means that my cable get programming voltage power from the computer's USB port, but maybe you have to connect 5V or 12V power to the red terminal? I don't know though, that's just a guess).
Old May 8, 2009 | 05:37 PM
555R's Avatar
thats probably the issue and earlier cable
maybe you can also give me some tips on why i cant get my aem to log on evoscan
its irking me
Old May 11, 2009 | 01:26 PM
fostytou's Avatar
EvoM Community Team
You must be on a different internets than me.
Old May 11, 2009 | 07:59 PM
555R's Avatar
well if you note also my cable only has 6 and not 8 pins
i guess 11 and 9
Richard.Son
Dec 10, 2015 07:33 AM
WhiteLightning6
Mar 14, 2015 11:37 AM
JrCRXHF
Jan 31, 2012 11:10 AM
neilm
Nov 1, 2011 02:54 PM
riXrax
Jan 27, 2010 04:36 PM
