What does "inheriting evo9base_20081101" mean in Task Info field?
Just a newb here trying to get my learn on....
In the Task Info field, for IX maps (both the ROM I took from my actual EVO IX, to any map I mod or receive from a friend), I repeatedly see:
Then for an EVO VIII map, I see:
-Why does my map inherent these?
-What would happen if I were to erase 'evo9base_20081101" from my C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo directory?
-Why doesn't my downloaded, oem ROM I took from the car inherit '88590015.xml' if anything as this is 'Internal ID' as displayed by EVOSCAN?
88590015 (89 tables) inheriting evo9base_20081101 (135 tables)
96940011 (68 tables) inheriting evo7base_20081101 (127 tables)
Ok, doing some more reading and watching the video tutorials, I see EVOSCAN is a graphical interface to tie together all the difference XML files. The ROM or .hex file is just a gathering if the difference XML files.
But when u change a table in EVOSCAN, just as a timing map to add more timing, or you turn off lean spool...what XML file is that written to? (U're only saving the ROM or .hex, when u select save in EVOSCAN, right?) I know you can modify given XML files to add 'features' into EVOSCAN as the developers discover more and more, but where are ~my~ changes written if the ROM or .hex file is just a gathering of the XML files in my directory?
The inheritance of the two files are common entries in all Evo 7-8 and Evo 9 Roms. The individual files hold the differences between the roms and/or the address locations of the common map points.
The XML is NOT written to when you change a point in your rom the hex file you load is. The XML just defines what part of the binary you're looking at.
Try this analogy on for size:
The Rom hex/bin file is like a library, the XML files are like index cards telling you where a book is in the library. So you go to the index cards find the book you want to change or write in then grab it off the shelf in the library and write changes in the book putting it back in the library.
Then each of the specific rom ID XML files has maps specific to that rom ID.
jmcmill3
Nov 22, 2009 12:13 PM
88590015xml, back, bster13, d9, ecuflash, evo, evo9base20081101, field, id, inherets, inherit, inheriting, map, modify, rom
