Virtual Dyno Room-Dyno Simulator
Old Jun 27, 2009 | 08:16 AM
  #181
Jack_of_Trades's Avatar
Originally Posted by Mellon Tuning
If I may make a suggestion or two:
Thanks for the suggestions Chris. I'm really glad you've decided to take the time to mess with my little project especially since I know you use DLL quite regualarly
1) include a macro to auto filter tps > 95%
I was going to have a filter for the TPS a while ago but then realized that a TONNNN of datalogs people sent had more than one pull recorded in them and/or they couldn't resist the urge to NLTS into 4th for a short bit lol. Both made the logs crazy screwy. This makes users have to crop their pulls themselves a portion of the time. So I decided to have the user do ONE thing themselves, the cropping. Maybe in the future I'll add an 'auto-filter' check box so the users can opt to enabled/disable the auto-search with the TPS column added.
2) widen the LogEntrySeconds column so you can see the full name, some people are grabbing the wrong column from the log because it looks like another one
I can edit that, thanks
3) column c and d aren't wrapping correctly because it's too narrow as well.
I will look into columns C and D. What version of OpenOffice or Excel are you running? OpenOffice this next revision will have two separate downloads for Excel and openOffice since they have slight differences which require the coding/visual layouts different.
4) support for overylaying 3 pulls, not just 2
You have NO idea how hard it is to have 2 logs overlap with the immense amount of data required, plus fit everything on a screen! I think 2 is all I can handle Its literally requires 2 totally separate simulators to have 2 logs overlap. I think the majority of users will be quite happy that I decide to add the 2nd comparison log for them and call it a day. Maybe down the road when my head stops spinning I can expand it lol.
1) include evo 7 and evo 10 transmission options
way ahead of ya! Just trying to find the different year/gear ratio combo's available for all of the VII's and X's.
2) Make a EVOM dyno correction standard drop down option so people aren't posting up random graphs and trying to compare cars. I suggest something between the mustang and dynojet since they are largely regarded as stingy and generous respectively.
Thats a good idea. I will add that as a between the average DJ and average MD
This revision is HUGE. I have dialed things in 10x more than v5.3 plus added a crapload of features (plus I keep adding them with everyone's requests/suggestions) so its taking longer than I first predicted. I REALLY wanna have it done by the end of the weekend but I don't know if I will get the free time without the wife getting neglected.
Thanks for everyones support! Really, it means a lot.
Old Jun 27, 2009 | 06:30 PM
  #182
Well, I really can't do this because when you copy a 'column' from another page (your datalog) it also copies the column width so even if I resized my column width on the 'Data Entry' page, the second you paste your LogEntrySeconds row into it the column width will change to whatever it was in your datalog. Maybe I can find a way around it later but for now I just can't find a way how while still allowing users to paste the entire column quickly.
Old Jun 27, 2009 | 07:57 PM
  #183
Spins4's Avatar
Haha..I got sneak peaks of version 5.4 ..suckers
Let me tell you, this guy is one dedicated ****!! Awesome work man...def digging the new features!
Old Jun 27, 2009 | 08:37 PM
  #184
vmrevo9's Avatar
Veteran: Air Force
i just downloaded 5.3 and it seems pretty cool cant wait for 5.4 donations a coming!
Old Jun 28, 2009 | 04:29 AM
  #185
SiC's Avatar
SiC
Just in case you need the gear ratios for the EvoX here it is:
GSR (5 Speed MT)
2.857
1.950
1.444
1.096
0.761
Final
4.687
MR (6 Speed SST)
3.655
2.368
1.754
1.322
1.008
0.775
Final
4.062
Old Jun 28, 2009 | 07:54 AM
  #186
Excellent! If anyone wants to track down all of the gear/model options for the evo VII's,that would save me some time finishing v5.4. Trying to launch it in 4 hours from now.
Old Jun 28, 2009 | 08:59 AM
  #187
Evoryder's Avatar
EVO 7 GSR-RS(5SPD MT)
1st: 2.928 - RS: 2.785
2nd: 1.950 - RS: 1.950
3rd: 1.407 - RS: 1.444
4th: 1.031 - RS: 1.096
5th: 0.720 - RS: 0.825
R: 3.416
Final:4.529
Old Jun 28, 2009 | 09:20 AM
  #188
Nice, thanks guys!
Old Jun 28, 2009 | 09:26 AM
  #189
leecavturbo's Avatar
what dyno settings would i enter and where for uk dyno dynamics?
Old Jun 28, 2009 | 09:33 AM
  #190
Not a clue. In order to know for SURE, I would need someones datalogs from their dyno session on a dyno dynamics dyno over there. I'd also need to know the vehicle weight entered into the dyno software, the tire size of the vehicle tested and the UNcorrected hp/tq results from that pull.
As time goes by and I acquire more and more data from members/tuner shops I will be able to add more dyno types and even specific shop dyno's to the list. Do some searching and see where dyno dynamics results usually compare to dynojets and mustang dynos to get an idea.
If its somewhere in the middle, just look at the correction factor used by both dyno types and manually enter in your own correction value somewhere in the middle. Just enter in your own correction value in the 'USER Correction #1' box and select 'USER Correction #1' from the drop-down list located in the 'DYNO Correction Factor' box.
Old Jun 28, 2009 | 03:27 PM
  #191
v5.4 now supports all Evo 7 platforms (even the rare 5-speed automatic GT-A version!) and the Evo 10's Just need to make the visual updates for the OpenOffice version and it will be launched very shortly!
Again, as always, this will need to be put through its paces by all of you to help me find any errors I may have overlooked in the coding.
Old Jun 28, 2009 | 06:50 PM
  #192
bambooi's Avatar
Error in open office for me :-(. Waiting on 5.4
Old Jun 28, 2009 | 07:14 PM
  #193
Check back in 20 minutes
Still having issues with hidden columns still re-appearing after I save it and re-open it but otherwise I think its done for now. OpenOffice is a pain in my ***.
Old Jun 28, 2009 | 07:29 PM
  #194
All set guys. One file SHOULD work for any platform though OpenOffice seems to not allow me to hide unused columns to the right when i save it. Other than that it seems to be working.
I will be adding this link to the first page and updating the first post with the new info tomorrow.
The directions link in the program isn't done yet, hopefully tomorrow.
CLICK HERE TO DOWNLOAD 'VIRTUAL DYNO ROOM v5.4'
Old Jun 28, 2009 | 07:30 PM
  #195
compscibOi's Avatar
Developers, Developers, Developers, Developers...
