Virtual Dyno Room-Dyno Simulator
Nice. Just over 300whp on Buschurs dyno is usually good enough to sneak into the 11's with a good driver so I think its time for you to hit the track again and renew those 1/4 mile numbers!
You could have more power in your mid-range than he did which can easily explain why you could pull on a 'technically equal' car. You should put your Evo-M Comparator #'s in your sig since I have a feeling it will be one VERY respectable #!
You could have more power in your mid-range than he did which can easily explain why you could pull on a 'technically equal' car.470WHP/372WTQ EVO-M Comparator settings on Jack of trades Virtual Dyno!
Just created the DIRECTIONS tutorial webpage but i had to redo the link in the simulator to point toward the web address so if you'd like, re-download v5.4 one last time and it should be good to go!
Any more revisions will carry a new version number.
Thanks so much guys! Enjoy
The vehicle weight is probably one of the most important things to KNOW regarding your setup when it comes to getting accurate HP/TQ readings.....on a real dyno or on the simulator. As a reference, my 8 weighs roughly 3125 with all the usual bolt-ons,stock wheels, spare tire & jack plus a 1/4-1/2 tank of gas.
ok thanks. yes it does make a pretty big difference i noticed while altering the setting. i do have aftermarket wheels (5zigen pro racer stock rim size). their site says they weigh between 23-25lbs but i think the stockers are pretty close.
VDR is a hit! 5 stars!
Rolling Stone Magazine says:
Thanks guys. I'm still paranoid I missed something in all of that code lol. Its probably paranoia lol.
"I love VDR - purely because its so damn easy to use, just copy/paste and its done."
