No 2 step?????????
Old Jul 8, 2009 | 10:17 PM
fostytou's Avatar
EvoM Community Team
Originally Posted by crewdawg130
the switch is connected and not broken. You cant crank the engine with out pressing the clutch so the switch works....
Wrong switch. There are two switches. The starter disable switch has nothing to do with launch control on the evo. I recommend unplugging that one anyway (so you don't have to clutch in to start... obviously it carries a risk, but its also less wear on cold unlubricated parts).
The switch for the 2-step is closer to the top of the pedal and works inversely to this switch. (AKA NC, when your pedal is at rest it is open.)
Old Jul 9, 2009 | 12:15 PM
jrohner's Avatar
Mine has no 2-step on the 96530006 tephramod rom, but it worked fine on the 94170008 that the ECU came with.
Old Jul 9, 2009 | 12:23 PM
jrohner's Avatar
Maybe some roms use the clutch switch instead of or in addition to the speed sensor, instead of just the speed sensor?
Old Jul 9, 2009 | 03:31 PM
sti.this's Avatar
did it ever have a remote start on it? The switch(es) may have been tampered with.
Old Jul 9, 2009 | 06:45 PM
crewdawg130's Avatar
no.
Old Jul 9, 2009 | 07:01 PM
redleg225's Avatar
Check the muffler bearings. If that's good then drain the headlight fluid.
Love you.
03OZstocker
Lancer Engine Management / Tuning Forums
Mar 30, 2017 10:27 PM
audiofan
Apr 3, 2011 05:36 PM
ant_turbo
Oct 29, 2009 08:37 PM
trboboost91
Oct 15, 2007 07:30 PM
AutobonEvo
Oct 23, 2005 08:28 AM
