96530706 + DMA +LiveMap + SD - working
Old Aug 6, 2009 | 04:14 PM
  #151
l2r99gst's Avatar
Here are the logs...they are small enough if I keep them as .csv...the .dif format for LogWorks increases the file size too much.
File Type: zip
File Type: zip
Old Aug 6, 2009 | 04:25 PM
  #152
gear head's Avatar
It definately feels like a misfire to me.
Old Aug 6, 2009 | 04:26 PM
  #153
roger smith's Avatar
l2r99gst, I went through the thread seeing who was replying, I had the idea that maybe this problem is with the 96530706 rom only. You and gear head are the only two that seem to be running SD on that rom (according to this thread). One or two others have tried but seems like they haven't gotten to test driving stages yet.
Just another thought.
Old Aug 6, 2009 | 04:31 PM
  #154
l2r99gst's Avatar
I wonder if it's this ROM as well. The problem is that not too many people are running SD, period, whether with this ROM or not.
I noticed one other person complaining of similar symptoms on the 94170015 ROM, though. But I think others have tested SD OK, like mrfred and jcsbanks.
Old Aug 6, 2009 | 04:37 PM
  #155
Yeah. They have evo9s though so different roms. Just a thought to keep in mind. Maybe try this out on the 96530006. I wish I could but I don't have my IAT sensor installed yet and have no idea when I'll have time.
Old Aug 6, 2009 | 04:40 PM
  #156
l2r99gst's Avatar
No, one is an Evo 8. Also, someone else just commented he has this problem with this ROM.
Also, I did try with v5 of 96530006 with the same results.
Old Aug 6, 2009 | 04:42 PM
  #157
gear head's Avatar
The log I posted was 96530006 V5.10
Old Aug 6, 2009 | 05:01 PM
  #158
jrohner's Avatar
I'm having an issue with the 96530706 SD as well. It stutters sometimes when cruising in vacuum, and the fueling is off for a split second with a big MAP change -- decrease = rich, increase = lean. I was previously running the tephramod v510 96530006 with a MAS with no issues at all.
If anyone is wondering why they saw this post on two different threads, l2r99gst pointed me to this one after reading my post on the "Links to jcsbanks' Speed Density patches " thread.
Old Aug 6, 2009 | 05:03 PM
  #159
l2r99gst's Avatar
You may be able to fix up some of that issue with the asynch_vs_tps table. I added about 8 to all of the values. That will help with the leanness right as you press the throttle.
This stumble that has been mentioned in this thread is during normal cruise, at steady throttle, or slightly moving throttle. You probably are experiencing that as well. Just look at your IPW in the trouble area mentioned.
Old Aug 6, 2009 | 05:44 PM
  #160
jrohner's Avatar
Asynch_VS_TPSDELTA?
Anything available yet to adjust for that cruise issue?
Old Aug 6, 2009 | 05:53 PM
  #161
l2r99gst's Avatar
Code:
	<table name="Asynch_Acell_Enrichment" category="Fuel" address="1654" type="2D" level="1" scaling="uint16">
		<table name="X" type="Static Y Axis" elements="5">
			<data>pause_period</data>
			<data>min_TPSdelta</data>
			<data>Max_pulsewidth</data>
			<data>idle_TPSRange</data>
			<data>after_engine_start_addition</data>
		</table>
	</table>
	<table name="Asynch_VS_TPSDELTA" category="Fuel" address="38a2" type="2D" level="1" scaling="uint8">
		<table name="X" type="Static Y Axis" elements="9">
			<data>0</data>
			<data>1</data>
			<data>2</data>
			<data>3</data>
			<data>4</data>
			<data>5</data>
			<data>6</data>
			<data>7</data>
			<data>8</data>
		</table>
	</table>
	<table name="Asynch_TPS(Rpm) Limit" category="Fuel" address="38b2" type="2D" level="1" scaling="WGDuty">
		<table name="X" address="6622" type="Y Axis" elements="10" scaling="RPM"/>
	</table>
	<table name="Asynch_Accel_vsRPM" category="Fuel" address="38d0" type="2D" level="1" scaling="uint8">
		<table name="X" address="6622" type="Y Axis" elements="15" scaling="RPM"/>
	</table>
No one knows what the cruise issue is just yet. If anyone figures it out before me, they better tell me first.
Old Aug 6, 2009 | 05:57 PM
  #162
mrfred's Avatar
Can you post just one portion of a log that clearly show the behavior? I don't need any other part.
Old Aug 6, 2009 | 06:10 PM
  #163
l2r99gst's Avatar
No problem...I'll grab the section from one of the screenshots and create the log (.dif) from that.
Give me a minute or two.
Eric
Old Aug 6, 2009 | 06:24 PM
  #164
l2r99gst's Avatar
Here you go...most everything deleted except the items you wanted and one small section of the log. This is in .dif format that you can open in Excel or LogWorks.
Old Aug 6, 2009 | 09:59 PM
  #165
mrfred's Avatar
I don't see a strong correlation with any of the SD-related variables (MAP, RPM, MAT, master load, calculated MAF Hz). It will be interesting to see what you get when you get logs in MAF mode.
