96530706 + DMA +LiveMap + SD - working
Old Aug 13, 2009 | 06:51 PM
  #211
tephra's Avatar
Eric - how are you doing MAT in this ROM? is it using the MAFIAT sensor/harness?
Old Aug 13, 2009 | 07:20 PM
  #212
l2r99gst's Avatar
MAT sensor is wired into fuel temp ADC, using mrfred's mat patch.
Old Aug 13, 2009 | 07:22 PM
  #213
tephra's Avatar
ok
how you doing the MAT scaling? i didn't think 96530006 had "fuel temp" (obviously it has the ADC, I just didn't think it converted it to a DegC value)
Old Aug 13, 2009 | 07:24 PM
  #214
l2r99gst's Avatar
Scaling is done via the MAT patch. (I think I added that to my post above while you were replying.)
Old Aug 13, 2009 | 07:25 PM
  #215
tephra's Avatar
sorry - can you link me to the post?
I am just double checking that its ok to remove the MAT stuff from my V7
Old Aug 13, 2009 | 07:28 PM
  #216
l2r99gst's Avatar
Here you go.
Edit: BTW, I'm not sure if you have been following this thread or not and my issue with the jumpy IPW in a small map/rpm range with SD....but if you see anything in the code or have any suggestions, let me know.
Eric
Old Aug 13, 2009 | 07:33 PM
  #217
tephra's Avatar
thanks
yeah i have been reading it... not sure what the problem could be - but doing a full trace of logging from start MAF_SOURCE_0 -> IPW might be in order
Old Aug 13, 2009 | 07:36 PM
  #218
l2r99gst's Avatar
It would be easier if I could read the ROM code so I knew what variables to log. I have logged a few key ones so far with nothing suggestive of the issue yet, though.
Of course I'm not asking you to waste time with this...just if you run through some of the code and routines when writing your patches and something comes across that is worthwhile logging.
Old Aug 14, 2009 | 05:51 PM
  #219
tom04841's Avatar
Would anyone happen to know the tables for cold starts on this rom? My car takes about 8 cranks to start, then runs like *** until it warms up. I have to keep reving it until the needle for the temp guage starts to move before it will stabilize. Once war, it starts and idles fine.
Old Aug 16, 2009 | 09:47 AM
  #220
YaroRS's Avatar
guys, can someone help me. I want to run 96530706 rom with livemap, but without SD patch. Is that possible to do so ? I got Logic's pathc for DMA/live map, added all tables to XML file, but the live map program says "unable to open port", why could this happen ?
Old Aug 16, 2009 | 11:36 AM
  #221
fjo_newport's Avatar
Get the new version of ECU flash. I believe they are in there. But if not:
Code:
	<table name="Start IPW latency mcsec" category="Fuel" address="1569" type="1D" level="1" scaling="McSec"/>
	<table name="IPW comp starting" category="Fuel" address="3822" type="2D" level="1" scaling="IPW mcsec">
		<table name="Water temp" address="69be" type="Y Axis" elements="8" scaling="Temp"/>
	</table>
	<table name="Cranking Primer (First Pulse)" category="Fuel" address="5b3a" type="2D" level="3" scaling="IPW mcsec">
		<table name="Engine Temp" address="69f4" type="Y Axis" elements="11" scaling="Temp"/>
	</table>
	<table name="IPW comp warmup 1" category="Fuel" address="3712" type="2D" level="1" scaling="IPW mcsec">
		<table name="Water temp" address="69d8" type="Y Axis" elements="9" scaling="Temp"/>
	</table>
	<table name="IPW comp warmup 2" category="Fuel" address="3722" type="2D" level="1" scaling="IPW mcsec">
	</table>
	<table name="IPW comp running 1" category="Fuel" address="3732" type="2D" level="1" scaling="IPW mcsec">
	</table>
	<table name="IPW comp running 2" category="Fuel" address="3742" type="2D" level="1" scaling="IPW mcsec">
	</table>
	<table name="IPW comp running 3" category="Fuel" address="3752" type="2D" level="1" scaling="IPW mcsec">
	</table>
	<table name="IPW comp running 4" category="Fuel" address="3762" type="2D" level="1" scaling="IPW mcsec">
	</table>
	<table name="IPW comp running 5" category="Fuel" address="3772" type="2D" level="1" scaling="IPW mcsec">
	</table>
	<table name="IPW comp running 6" category="Fuel" address="3782" type="2D" level="1" scaling="IPW mcsec">
	</table>
	<table name="IPW comp starting" address="3822"/>
Old Aug 16, 2009 | 02:59 PM
  #222
golruss's Avatar
Could someone take a look at the attached log and give me some feedback.
The JDM boost values are not matching my boost guage its reading about half the guage reading and the MAT reading is stuck on -38.xxxx.
Help me please.
Old Aug 17, 2009 | 05:40 PM
  #223
EVO8LTW's Avatar
I'm just starting to tune my SD set-up, but I already feel the issue that Eric is talking about. It's right around 2,000 at light cruise. 5th gear and 50 mph triggers it. I won't be able to do much tuning on my set-up because I'm about to leave on a trip, but I just wanted to throw it out there. I'm running a 3.5 bar remotely mounted Zeitronix MAP sensor and 1050cc injectors.
I just curious...are others running SD finding that their cars run smoother, about the same, or worse? My car definitely feels a little choppier, like the timing fluctuations are more granular or something. Hopefully, it's just the load cells not being dialed in yet. It felt that way with the loads too high (rich) and too low (lean). The issue at 2000 rpm cruise doesn't bother me because I almost never cruise at 2000 rpm. I keep the revs higher due to having a Red under the hood.
It is very cool to disconnect the MAF sensor though and have everything still work!
Old Aug 18, 2009 | 09:49 AM
  #224
jcsbanks's Avatar
Mine felt smoother everywhere than using the MAF, and I am very fussy indeed.
I can only think that there is something different with the ROM being tested to my JDM Evo IX, but I have too many other projects on the go to develop this further.
Old Aug 18, 2009 | 10:45 AM
  #225
YaroRS's Avatar
guys, does anyone know why livemap says cannot open port ?
