96530706 + DMA +LiveMap + SD - working
Old Oct 4, 2009 | 10:58 PM
  #256
ziad's Avatar
sorry i realised that i had the constructor wrong.... yes source code when the program is working better will be released. unless u guys want to see spaghetti code j/k
attaching it again... hopefully its better now please dl it again logic.
installation instructions
u will need the latest zedgraph.dll file and rename the zip file to rar and then extract it.
zedgraph dll can be downloaded from http://sourceforge.net/projects/zedgraph/files/
for basic initial setup useage check my prev post.
File Type: zip
Old Oct 5, 2009 | 01:02 PM
  #257
jcsbanks's Avatar
Looks awesome, wish I still had my Evo. This is what I wanted people to do with the project
Old Oct 5, 2009 | 05:32 PM
  #258
golruss's Avatar
Error trying to open the file.
Old Oct 5, 2009 | 05:35 PM
  #259
logic's Avatar
Rename it to "EvoLiveMap.rar" after you save it, and try re-opening it.
Or, install 7-zip, because it automatically handles stuff like that.
Old Oct 5, 2009 | 05:56 PM
  #260
golruss's Avatar
Thanks logic, downloaded, tried to run it but got 'EVOLIVE MAP HAS ENCOUNTERED A PROBLEM AND NEEDS TO CLOSE'.
any ideas.
Old Oct 5, 2009 | 06:01 PM
  #261
logic's Avatar
You also need the latest version of zedgraph.dll from the ZedGraph distribution. Download the latest version, and put the DLL in the same directory with evolivemap.exe.
Old Oct 5, 2009 | 06:06 PM
  #262
ziad's Avatar
sorry i didnt make it too user friendly yet
btw if it does crash can you please email me the debug trace (hopefully the program shows it) once its little more stable and a few more of the features are added i will make a basic installer
Old Oct 5, 2009 | 06:28 PM
  #263
golruss's Avatar
Ok Thanks.
Old Oct 12, 2009 | 02:44 AM
  #264
mrfred's Avatar
Eric, I have an idea of what maybe causing your SD issue. Please post your 9653 xml file.
Old Oct 12, 2009 | 03:12 AM
  #265
leecavturbo's Avatar
also getting crashes here
Old Oct 12, 2009 | 03:17 AM
  #266
mrfred's Avatar
oops. I meant to write that I suspect I have found what is causing Eric's SD issue.
Old Oct 12, 2009 | 08:31 AM
  #267
l2r99gst's Avatar
Sweet! Give me a few minutes to get on my laptop and gather my XML files. I have so many going around since the various versions of V7 have been out, since I name each one a different internal ID. I'll post the XMLs that I last used for the ROM/version in this thread.
I sure you hope you found the cause...I have had my new Dejon 4" intake and Amsoil filter sitting here for months waiting to go in.
OK, here are the XMLs that I have on my laptop for this ROM.
File Type: zip
Old Oct 12, 2009 | 09:48 AM
  #268
mrfred's Avatar
Convert the scaling on these tables from "IPW mcsec" to "uint8", and then post screen shots of the tables.
Code:
<table name="IPW cold start Decay 1" category="Fuel" address="3712" type="2D" level="1" scaling="IPW mcsec">
<table name="Water temp" address="69d8" type="Y Axis" elements="9" scaling="Temp"/>
</table>
<table name="IPW cold start Decay 2" category="Fuel" address="3722" type="2D" level="1" scaling="IPW mcsec">
</table>
Old Oct 12, 2009 | 10:34 AM
  #269
l2r99gst's Avatar
Will do in about 5-10 minutes. I'm nearly certain I didn't touch those table though, so they should be stock. When I was testing SD, I was on stock injectors and pump gas...no E85 or 1250s yet.
Eric
Old Oct 12, 2009 | 10:39 AM
  #270
l2r99gst's Avatar
Here you go:
