Interpreting 2 Byte Load
Old Jul 21, 2009 | 10:48 PM
Werd's Avatar
I started logging 2 byte load yesterday and all the number's I'm getting are are from like 2700 to 4800. And all the tables in ECUFlash are up to 300... I have no idea what any of this means so can someone kind of explain what I'm looking at because I can't really make any changes based on what I know.
Old Jul 21, 2009 | 10:50 PM
PeteyTurbo's Avatar
You need to make changes in the mut table specific to your rom for 2 byte logging to work.. There is a thread dedicated to this in this section..
Old Jul 21, 2009 | 11:10 PM
tephra's Avatar
yeah that's not right - as per above - did you change the MUT table for 2byte load?
Old Jul 21, 2009 | 11:28 PM
PeteyTurbo's Avatar
lol I guess it can also depend on how old of a version of evoscan you are using.. For awhile I was using really old versions and doing .xml's on both sides lol
Old Jul 22, 2009 | 07:29 AM
Werd's Avatar
I'm using v2.6 and no I didn't make any changes to the MUT table.
Old Jul 22, 2009 | 04:50 PM
tephra's Avatar
you need to modify the MUT table.
Or you can use one of my tephramods with 1byte load
Old Jul 22, 2009 | 06:43 PM
Werd's Avatar
Well what would be better? lol.
Old Jul 23, 2009 | 07:34 AM
Rob_GPT's Avatar
"better" is relative. If you are just getting started I would change the values in the MUT table. You'll learn something and it's pretty basic/not changing much.
You need to go to the "official 2 byte thread" and find your romID. Find the values for 2byte load.
Open ecu flash and read your rom.
Check to see if your MUT table is already defined. (Mine was) If not it'll need to be. There's info in the 2 byte thread.
If it is then simply change the first two values that aren't FFFF to what they are listed as in the 2byte thread.
Flash the rom back to the car
Log away.
Kaveeth
Jan 26, 2015 05:35 PM
Anubis18
Jun 23, 2013 11:43 AM
mines5
Jun 18, 2013 09:49 AM
fuzzychi
Jul 21, 2010 08:56 PM
