Evo8 ECU in a 1G DSM in the works!
Has anyone here gotten their 1g working with A/C controlled via the ECU? Keydiver had posted long ago that the pin hookup should be:
evo 45 -> DSM #7
evo 8 -> dsm 65
He also mentioned that the factory A/C works by supplying 12 volts through the A/C switch to pin 7, and dependent on ECU control (temp, RPM) the ECU pulls 65 to ground.
I hooked my harness up with those two wires and for whatever reason my A/C switch doesn't even have power.
Can anyone help if they have gotten this to work?
evo 45 -> DSM #7
evo 8 -> dsm 65
Alright, I got the A/C stuff figured out, those were the correct pin outs.
Next question, what is everyone logging ECT with? I'm not so concerned that it is or isn't working, but I'm thinking if the ECU is seeing the wrong values then it's going to throw everything else off. My two fields in evo scan are:
07 - x*1.8+32
07 - -1.45*x+308
My coolant temps just at idle are showing up around 225* with the first one, even though fans may not be on. It's only about 50* here today and I have a huge aluminum radiator, and the fans DO come on eventually, so I'm pretty sure that isn't the correct temp.
Anybody logging anything different in evoscan?
07 - x*1.8+32
07 - -1.45*x+308
I'm willing to do it. My first task is to secure an Evo 8 ECU, and get my car running.
After that, I'll look in to finding just a regular 2003 or 2004 Lancer ECU, and see what I can do.
I know I'm going to need support from those that came before me in order for me to get this working.
The least I can do is leave something for those that come after me.
I looked in to this a while back. I believe there was only two pins that needed to be swapped between the lancer and evo ecu's (fuel temp or fuel pump relay cant remember for sure). No one could confirm BCS control using the lancer ecu, or a way to use another output as BCS since most lancer guys were running low boost. If someone wants to send me a lancer ecu ill be happy to toss it in and see.
