quick question
Old Aug 11, 2009 | 12:45 AM
fknlowpsi's Avatar
quick question
ok i have a 1.3 cable and i can only read and flash with 1.29. the question is can i edit and tune with 1.42 and flash my car with 1.29??? i havent tried it yet i am wondering if anybody has and has had any trouble???
Old Aug 11, 2009 | 12:51 AM
tephra's Avatar
yes - that will work fine, just dont confuse yourself
alternativley you can contact the manufacturer of the cable (either tactrix or evoscan) and ask them to "update" the cable to work with the newer version of EcuFlash
Old Aug 11, 2009 | 12:55 AM
fknlowpsi's Avatar
thanks tephra. i figured it would work just havent tried it. another quick question when converting from 96420008 to 96530006 i just have to disable the immobilizer via ECU periphery patch correct????
Old Aug 11, 2009 | 01:03 AM
tephra's Avatar
yes you can do the periphey bit change to disable the immobiliser.
Alternativley you can copy the 0xFAA bits from 96420008 to 96530006 and keep the immob
See the Wiki Entry for more information
Old Aug 11, 2009 | 01:11 AM
fknlowpsi's Avatar
thanks tephra. i will try keeping the immobilizer first then disable if doesnt work. now i wish it wasnt 1:30am here so i could go try this ish.
Old Aug 11, 2009 | 10:44 AM
fknlowpsi's Avatar
ok went and flashed the car with immobilizer still on. car wont start so turned off immobilizer via periphery. now when i try to reflash ecu clicks and computer wont connect. HELP!!
Old Aug 11, 2009 | 10:55 AM
fknlowpsi's Avatar
i am getting this code now????
[19:11:28.609] sending init sequence 1 (0001)
[19:11:31.859] sending init sequence 1 (0003)
[19:11:35.109] sending init sequence 1 (FFFF)
[19:11:37.812] no response to any known code
[19:11:37.812] interface close
ecu unlocker????
Old Aug 11, 2009 | 11:00 AM
fknlowpsi's Avatar
double post
Old Aug 11, 2009 | 11:44 AM
fknlowpsi's Avatar
ok my ecu was locked. so i reflashed with immob diabled thru periphery. car wont start. HELP IM NEW!! lol
Old Aug 11, 2009 | 04:03 PM
tephra's Avatar
your not modifying the init code are you?
Old Aug 11, 2009 | 04:27 PM
fknlowpsi's Avatar
no tephra i did then i realize oops and i had to unlock my ecu but i got it running i just had to add 56d2 to perfinary (0).hex and she fired right up. now i just have to fine tune it. the car almost dies after taking it out of gear gunna try bumping up the idle map.
kiddsm95
Jan 25, 2016 03:37 PM
DIDYSIS
18
Feb 24, 2013 10:14 AM
F0RSAKEN
Feb 14, 2011 12:49 PM
jeri534
Oct 22, 2009 09:50 PM
burgers22
Nov 26, 2006 03:57 PM
