Can/how do I disable the MPD sensor??
Old Aug 17, 2009 | 12:02 AM
Evo_Jay's Avatar
I just got a new (to me) 04 RS. It came with the complete zeitroix setup. It also came with Road Race Engineerings "Manifold Differential Pressure (MPD) Sensor Adapter" (http://www.roadraceengineering.com/evo.htm half way down). I want to use it to connect my zetronix boost sensor to the IM (check the link to get what Im saying). To do that I would have to disable any test or things looking for the MPD. So can it be done?
Old Aug 17, 2009 | 12:37 AM
RoadSpike's Avatar
Check out my thread on getting the adapter.
https://www.evolutionm.net/forums/ec...connector.html
Plus you'll need to get the settings for the rom right.
https://www.evolutionm.net/forums/6563042-post582.html
Follow the instructions for install on this thread.
https://www.evolutionm.net/forums/ec...tructions.html
Old Aug 17, 2009 | 02:20 PM
Evo_Jay's Avatar
I think i didnt explain what i would like to do exactly. I dont wanna run the zeitronix MAP sensor to the ECU (thats what that info seemed to be pointing too, if Im not mistaken). I want to install the zeitronix MAP sensor (using the RRE adapter) in the spot that the factory MPD. I will be loggin the zeitronix MAP sensor using zeitronix hardware/software.
So what i actually need to know is how to disable/remove the factory MPD sensor completely (with no CEl light or running problems) or if I even that can even be done.
Old Aug 17, 2009 | 02:24 PM
RoadSpike's Avatar
I'm not sure then hmm its supposed to be tied to the EGR system so I suppose if you disabled that it would work. Can always force a ODBII pass and run it anyways.
Old Aug 17, 2009 | 03:51 PM
Evo_Jay's Avatar
Well, im smogging it in the next 2 weeks (as soon as I get a complete stock exhaust setup to use), then I wont have to smog it for 2 years so i wouldnt mind disabling the ERG and such. Its not my DD
Old Aug 17, 2009 | 05:35 PM
EVO8LTW's Avatar
It depends on what ROM you are running. I have an 04 RS and am running the Zeitronix sensor to both the ZT-2 box and the stock ECU. For logging, it's better to read it from the stock ECU because there is a slight light through the serial->USB converter. I'm running a Euro ROM from a car that didn't have EGR, so there's nothing to "patch." If you are going to keep your native ROM, then you'll need to patch your ROM so you don't get a CEL/emissions fail from the EGR test. I know this probably all sounds Greek if you haven't been reading here for a while. Probably better to leave it alone for 2 weeks and start in on it after you have a clean emissions bill of health.
Old Aug 17, 2009 | 06:10 PM
Evo_Jay's Avatar
No none of it sounds greek. Just so you know this is my third evo and I wrote the how-tos for Ecu controlled boost w/ stock solenoid and GM. I have used patched ROMs and I have done direct boost, disable O2, JDM MAP, etc. Also I still lurk here and such, too
I had zeitronix in my last evo. I logged boost and AFR from the zeitronix though EVOscan and it worked perfectly (this was before the JDM map was being used). Also i dont really wanna input it into the ECU. Just trying to get rid of the MPD and do logging like I used to.
And of course im going to do my smog before I install my zeitronix stuff.
Old Aug 18, 2009 | 09:23 AM
Evo_Jay's Avatar
Anyone??
stealthMR
Toronto Lancer Club
31
Sep 27, 2017 07:38 PM
mar387
Mar 6, 2016 10:28 PM
macPSU
Northeast Region
Sep 6, 2013 08:28 AM
5gmirage97
Dec 16, 2011 10:59 AM
coolguycooz
Oct 20, 2006 05:58 PM
