The DTC Disable thread (P1235, P1241, P1238, etc)
Old Aug 12, 2010 | 05:42 PM
  #436
xPRimNT's Avatar
Originally Posted by tephra
yeah it will probably work.
just ENSURE the "before value" matches...
Yes, ALWAYS ALWAYS ALWAYS.
Old Aug 13, 2010 | 03:57 PM
  #437
Guru's Avatar
Got Tephra mods working awesome (thank you Tephra). Now the only DTC I'm getting is P0011 which is intake camshaft too far advanced. I don't have any sites that get more than 15 degrees advanced so I suspect maybe the JUN 272's are just too big and the ECU thinks something is wrong. Tephra any way you can look into this one? Would love to have the CEL off. Anyone else with man size cams have this issue?
Old Aug 13, 2010 | 04:02 PM
  #438
GST Motorsports's Avatar
I would lean more towards bad/flakey sensor or something wrong in the install.
We've had a couple locals with that code on stock cams and stock ROM and it went away once the sensor was swapped for a known good one.
- Bryan
Old Aug 13, 2010 | 05:03 PM
  #439
Guru's Avatar
Install is perfect and car running strong! I do see that the car is very sensitive with the cam advance. I had to even out the advance under vacuum as any major changes would cause major changes in airflow. Same goes for the exhaust MIVEC. Idle is stable but very rough sounding even at 970 RPM idle speed. I suspect the JUN 272's are a bit bigger than other advertised 272 camshafts out there.
Old Aug 13, 2010 | 07:29 PM
  #440
tephra's Avatar
it shouldn't matter how big your cam is
a degree is a degree
either bad sensor, or your MIVEC is lagging behind target too much... ie bad oil control valve...
Old Aug 14, 2010 | 08:26 AM
  #441
Guru's Avatar
I'll check sensor but I'm leaning towards the control valve. It did want to come apart when I removed head and I thought I fixed it but perhaps I need a new one. Thank you everyone!
Old Aug 22, 2010 | 04:27 PM
  #442
evo_q8's Avatar
i have done the CEL disable on an MR and there seems to be a problem -
Was driving my friends SST Evo X and it was a total joy.. but he was complaining about a few problems that he was having... the most interesting and confusing one being this -
When cruising lets say at about 40-50 miles in 5th gear and you need to make a 90 degree turn, as we turn, the car downshifts to 3rd gear and when we step back on the throttle, there is NO response.. we tap it like 5-6 times and its just dead! The car is running but there is ZERO throttle response... this was really confusing! Any Ideas?
Gunzo Replied -
Originally Posted by gunzo
the signal sent from the engine and your throttle is not agreeing .. this sends the SST into a state of limbo until the disagreement is resolved .. usually a lower speed / rpm or TPS ..
Happens to SSTs who are tuned with all the CELs disabled
So whats the solution here?
Old Sep 18, 2010 | 12:02 PM
  #443
SiliconTek's Avatar
Has the P0140 disable been found for 2008 USDM yet?
<table name="DTC P0139/P0140 Disable 0x1 -> 0x0" category="Misc" address="503b2" type="1D" scaling="Hex8"/>
I tried this and it no worky.
Old Sep 18, 2010 | 07:07 PM
  #444
Golden's Avatar
What is your Ecu Options #2 bit 1 set to?
Old Nov 8, 2010 | 02:28 PM
  #445
tephra's Avatar
Alright dudes - I finally sorted out P0140 for you Post #1 updated...
Thanks Clipse3GT for testing the fix
Old Nov 8, 2010 | 04:07 PM
  #446
xPRimNT's Avatar
Nicely done sir.
Nicely done.
Old Nov 8, 2010 | 07:51 PM
  #447
stokEd's Avatar
Old Nov 8, 2010 | 07:58 PM
  #448
kozmic27's Avatar
I dropped this into my evo10base, and so far it at least looks right for every rom I've opened that uses it (5269:5305), or at least the numbers match. I will test it on my MR hopefully this weekend, but it looks right.
Old Nov 15, 2010 | 11:37 AM
  #449
criptballer's Avatar
question, so i've put all this patches and other fixes into my 5268 roms because i own a GSR, but a guy wanted me to turn off a couple of DTCs in his MR 5269 and when i pulled up his map on ECUflash i saw that it still pulled up those same tables. but the thing is, i haven't put anything in my 5269 xml file. as a matter of fact, when i open the 5269 xmls they're very "bare bones" if you will. so anyways, i tried to put all on FFFF and what not and most of the address are the same, not realizing that some aren't, i still put the fix and it bricked his ecu. so we benched it and now i'm dong research on it. The code he keeps getting is P1235 and it throws him into limp mode, kinda weird. he's got FP green, dw1000s on e85, and mx1 cams. anyways that's besides the point. my question is, do the 5269 roms inherit from the 5268? if so, do i just need to add the 5269 fixes into the 5269 xml and label the tables "MR" or something so i know the difference? i just don't get why it still pulled those tables when it was a different rom.
Old Nov 15, 2010 | 01:44 PM
  #450
SiC's Avatar
SiC
Yes it does inherit the 5268 xml and that is why it showed up in the 5269. You can just enter the specific address for 5269 within ECUFlash. Open a 5269 ROM in ECUFlash and click (highlight) the specific item you want to edit. Right click and select edit map. Map sure you are on the 5269 tab and just enter the correct address for 5269. This basically will enter a new line in the 5269 xml and it will not use the inherited 5268 address.
