TephraMod V7
Old Oct 27, 2013 | 01:05 PM
  #2986
brusinn's Avatar
Originally Posted by audiofan
You could try a older version of tephra (V5), no big maps there
does v5 have launch map ?
Old Oct 27, 2013 | 01:12 PM
  #2987
audiofan's Avatar
Yes, launch maps and NLTS
Old Oct 31, 2013 | 01:32 AM
  #2988
Ads9's Avatar
Hi Tephra,
Have you got a V7 file for 88570008 (UK/ JDM Evo IX)?
Keep up the great work!
Cheers!
Old Oct 31, 2013 | 10:01 AM
  #2989
Tachyonzero's Avatar
hi,
I have a 98640014 rom, Does anybody has equivalent rom with OBDII metadata options?
thanks.
Old Oct 31, 2013 | 01:20 PM
  #2990
todd6027's Avatar
Originally Posted by Tachyonzero
hi,
thanks.
you can use v7 90550001
Old Nov 6, 2013 | 05:49 PM
  #2991
domyz's Avatar
Not a big issue, just wanted to share a little bug in the valet mode routine:
Considering I have to let my car to a local shop on thursday night for giving it time to dry for a rust protection treatment, I switched it from dual map to valet mode. It's the first time I do it (tephra v7). I set the rev limiter at about 2500RPM, all is okay. But I found the RPM to be a little low for first gear.
I set it at 3100RPM and second and third gears REV limiter works. The issue is that you can pass through the Rev limiter in first gear. I think this has to do with the first gear accelerating too fast, not giving enough time to ECU to react. As soon as you pass this limit once, the car stays in valet mode, but has no valet REV limit in any gear. Issue disappear when shutting the car and switching back to normal map and returning to valet mode.
Sorry if my explanation is poor, this issue has not enough importance to spend an hour on it
Old Nov 8, 2013 | 05:08 AM
  #2992
Ghostdriver22's Avatar
Sorry if this is a repeat question. I purchased my car with the tephra mod installed. I want to get into it this weekend with a friend of mine who has a 1.3 cable. Where do I download software? Do I only need evoscan for 25$? Is the tephra software on a site I can download? Thanks in advance
AJ
Old Nov 8, 2013 | 06:49 AM
  #2993
domyz's Avatar
AJ
Ecuflash is needed for tuning, and evoscan is needed for logging. Tephra mod doesn't change anything about software.
There is a definition file for each software (evoscan, ecuflash)
For Ecuflash, you need the right XML for your specific modded ROM from tephra v7 page.
For Evoscan, the xml pretty much contain everything you need.
Old Nov 9, 2013 | 07:03 AM
  #2994
Thank you Dom!
Old Nov 12, 2013 | 06:00 PM
  #2995
tsitalon1's Avatar
Can anyone tell me if the OP is still current?
I bought a used Evo IX with a pro tuned rom (88590015). Rom has init code 173A.
I successfully unlocked it, and now would like to transition to Tehpra V7.
I'm not really a newb as I've had an Evo X in the past, but honestly I've forgotten more than I care to admit.
What's the easiest way to copy the tables to the Tephra big maps? Is there a tool for that?
Also, I assume for the init code, I should ensure its 0001 right?
Old Nov 12, 2013 | 07:35 PM
  #2996
ReaperX's Avatar
The OP has the majority of bells and whistles. There have been some updates for advanced fuel controls and what not. Post #3 has the big map translator tool.
Old Nov 14, 2013 | 03:58 PM
  #2997
tsitalon1's Avatar
Thank you!
I would assume I would need to copy Fuel/Timing/MIVEC/Inj Scaling tables over to V7. Also, set Init code to 0001.
The rest can be ironed out later right?
What should I use for immobilizer?
Old Nov 14, 2013 | 04:35 PM
  #2998
domyz's Avatar
Thank you!
For Immobiliser and Immobiliser hex, you have to use what you had in your stock ROM.
Old Nov 14, 2013 | 06:34 PM
  #2999
tsitalon1's Avatar
Copied the immobilizer code to V7, unfortunately my current working rom (88590015) doesn't list immobilizer hex. I'm not sure if it's missing XML's to see it or if it's disabled in FAA.
My FAA bit 2 is set to "0"
Any help?
Old Nov 22, 2013 | 10:43 PM
  #3000
Ryan4dc's Avatar
I had to copy two different numbers for the immobilizer. Not near my laptop, but you'll see it of you open all the tabs that say immobilizer.
