TephraMod V7
Old Sep 26, 2019 | 06:25 AM
  #3556
3kg's Avatar
3kg
Nice involvement on the ALS subject, I appreciate it.
I have a couple ECUs 6 and 7, all JDM and will post pictures when I find the time to take them, in order to add to your pictures.
If someone has the logging request for the SAS/ALS routine and knows how to incorporate that into OBD/Evoscan, then that would be a good diagnostic tool. Additionally (and that's what I did so far), logging IPW helps to find just about anything is happening.
ROM: On the table value side I don't feel like truely plausible tables have been made public/exist, nor the proof of functional ALS on stock ECU has been made. Thus there are 12 more or less known dependant and independant variables no one is sure to the result about. When considering ALS being that rather sophisticated routine, it would be a great starting point to have valide values to activate. If you like, you would need to remind yourself of the fact that ALS is a deceleration routine...
It would be so very nice to get a fresh grip on the ancient Evo stock ROM ALS hunt. Which is one I have spent more hours chasing than willing to admit.
Cheers
Kris
Old Sep 26, 2019 | 06:50 AM
  #3557
Biggiesacks's Avatar
Originally Posted by 3kg
Nice involvment on the ALS subject, I appreciate it.
Cheers
Kris
You should hit up Merlin, as in the guy who wrote the evo tuning guide. This is what I have for ALS in the 94170715 XML that I purchased from him. I have never messed with this stuff but he has clearly figured it out.
Old Sep 26, 2019 | 07:46 AM
  #3558
3kg's Avatar
3kg
Unfortunately, to my knowledge, nobody has publicly figured out how to tune nor to get ALS working on an E7 ECU/90550001, mods or not.
Old Sep 26, 2019 | 08:06 AM
  #3559
What I showed you isn't public either, that's why I'm pointing you his way. He does custom ROM disassembly.
Old Nov 1, 2019 | 11:12 AM
  #3560
Evo8Emperor's Avatar
Does anyone know if the 94170715 rom can be used with the IAT wire being used instead of the fuel temp sensor wire ? Or if so how i could go about changing to use the IAT wire if possible.
Trying to make a switch the 94170715 rom with 3D Speed density. Currently running 9653 V7 speed density with the IAT wire being used.
Having a no start issue and im thinking thats my problem.
Old Nov 18, 2019 | 07:11 AM
  #3561
MisterrTurtle's Avatar
Not sure if ill ever get a reply, But im chasing a ROM for my Evo 8 JDM, Cant seem to find any. Tried the other two and just constantly get engine lights for Minimum coolant temp not reached, Or the rear o2 sensor.
Old Nov 18, 2019 | 08:39 AM
  #3562
https://www.tephra.it/v7/
Old Nov 19, 2019 | 09:24 AM
  #3563
I've donated but have not got a response. As the JDM is by donation only
Old Nov 19, 2019 | 09:33 AM
  #3564
Have you tried sending him a follow up email?
Old Nov 20, 2019 | 02:58 AM
  #3565
I've sent him a email but haven't got a response. I'm pretty sure I got the right email.
Old Nov 20, 2019 | 11:19 AM
  #3566
evoscan's Avatar
Silver Sponsor
did you send the donation to evoscan paypal? I don't see any email. or did you send it to Tephra?
Old Nov 20, 2019 | 01:57 PM
  #3567
ZZA's Avatar
ZZA
Is there any complete 9653 xml with all the tables defined? Specifically looking for the ISCV related and decel fuel resume rpm tables. Not sure if my tables are all defined correctly.
Old Jan 20, 2020 | 07:25 AM
  #3568
darwin_evo's Avatar
Hi all, I am running the usdm evo 9 v7 rom on an edm model (since there is no rom for edm evo9). It's throwing a P0107 cel as the edm doesn't have a map sensor. Anyway to disable this using periphery bits?
Old Jan 23, 2020 | 08:31 PM
  #3569
redheat86's Avatar
I had a similar issue on 9653 variants and it was related to the way the rear o2 was disabled. There are threads related to this if you search for the the DTC code returned.
Old Jan 24, 2020 | 02:25 AM
  #3570
rjwkerkhof's Avatar
I am on track of something but onfortunately my car is off the road at the moment, somebody suggeted me to change a byte in the code in order to activate the solenoid output. I have compared it to ROMS which have approved ALS working but now I need to test it... will be continued!
