TephraMod V7
Old Dec 19, 2009 | 05:30 AM
  #1246
phenem's Avatar
Originally Posted by rdtech
been having problem to get the idle to run right. I've been testing 96530706 for a awhile now and have tried to look at it again today. I'm having a bit of issue with idle on an evo 8. Idle by itself is fine but when I drive and come to a stop, it dips all the way down to the point where its gonna die then comes back up. Its weird. I flashed the v5.10 (96420011) map and its fine again.
Phenem - have you encountered this. Am I over looking something. I've checked the idle tables and transferred the map from v5.10 over to .7
Logic, Tephra, JO, fostyTou - any idea whats going one here?
Yes, please read these threads:
https://www.evolutionm.net/forums/ec...-searched.html
https://www.evolutionm.net/forums/ec...ched-roms.html <-- if you are only running SD!
That should help you out!
Old Dec 19, 2009 | 08:00 AM
  #1247
phenem's Avatar
Fixed some things in my ROM in both MAF and SD versions and updated the XML's
Old Dec 19, 2009 | 08:20 AM
  #1248
nothere's Avatar
not downloading for me
Old Dec 19, 2009 | 08:21 AM
  #1249
rdtech's Avatar
Phenen - Its warm here is Cali...... or was warm when I tested it. Its under normal driving condition and not start up. I'll look at the link to see if it pertains to me.
Old Dec 19, 2009 | 10:28 AM
  #1250
Appauldd's Avatar
Copy over you Decel Fuel Cut tables from your stock rom to the new one. Also copy over the stock ISCV setting over to the new one.
These should solve your stall issue.
Old Dec 19, 2009 | 10:30 AM
  #1251
D-VO's Avatar
Originally Posted by 3gEclipseTurbo
ive tryed everywhere from 2k-5.5k nothing and completely stopped for maybe 20min. Its because of the clutch switches which we dont have. We need a patch from the Ecu God....tephra... PLEASE
(Nudge nudge) Offer Tephra money
Old Dec 19, 2009 | 11:33 AM
  #1252
rdtech's Avatar
Going to try that to see if it works.
Old Dec 19, 2009 | 11:56 AM
  #1253
chmodlf's Avatar
Could you be specific about what changes were made to the roms? For those of us who are already in play, is it possible to modify what we have instead of copying all of the tables over?
Thanks
Old Dec 19, 2009 | 12:01 PM
  #1254
Mautofied.IS300's Avatar
Thanks
Same thing I am wondering....and the mirror/download site are currently down.
-Will
Old Dec 19, 2009 | 12:07 PM
  #1255
nothere's Avatar
the maf version isn't working, i think the sd vrs is
Old Dec 19, 2009 | 12:17 PM
  #1256
rdtech's Avatar
I can host the file if need be. Let me know
Old Dec 19, 2009 | 12:22 PM
  #1257
fostytou's Avatar
EvoM Community Team
There was just another thread on what style of switch the car uses stock. Combine that with your DSM/3g clutch-to-start switch (disconnect it, I hate starting with the clutch anyway) with the appropriate signal and output and you should be all good!
Old Dec 19, 2009 | 12:29 PM
  #1258
phenem's Avatar
Yeah, I fixed the post, it got all messed up with spaces and stuff...should be good now.
The changes that were made were the following:
BOTH SD AND MAF:
Added the following XML and changed the bit to 0, per mrfred.
Code:
<table name="EGR System Enable/Disable" category="Other ECU Options" address="103d" type="1D" level="2" scaling="uint8"/>
Changed Periphery2 (FCA) bit 15 to 0 (last bit) to disable EGR completely and codes.
JUST SD:
Changed these tables to fix the throttle hang on decel issue, top is stock, bottom is zeroed out:
Old Dec 19, 2009 | 02:57 PM
  #1259
chmodlf's Avatar
Thanks. Happy and joyous holidays to all of us "tooners".
Old Dec 21, 2009 | 05:29 PM
  #1260
rdtech's Avatar
Would it be possible to just patch the 941700XX, 969400XX, 964200XX roms with tephra mod v7. This would fix alot of the other problems we are seeing. Just a thought.
