TephraMod V7
Old Oct 11, 2009 | 01:01 PM
  #121
phenem's Avatar
Originally Posted by mt057
I know we need to copy over the immob. code but do we alter the int. code as well or leave as is? Sorry for the noob question. Also I do not see maf scaling am I using the wrong one? Is the maf comp. table it?
Sorry I mis-read your questions.
Copy over YOUR immob. code into the downloaded ROM don't touch the int. code at all.
Copy the rest of your fuel/timing/any other specific tune maps over too.
Flash to ECU and log/test!
Old Oct 11, 2009 | 01:33 PM
  #122
fostytou's Avatar
EvoM Community Team
Dang, this thread blew up!
Originally Posted by Monochrome
Might I suggest adding the rear O2 sensor heater disable to this patch as well?
Code:
<table name="Rear O2 Heater Patch" category="Mods" address="2c62a" type="1D" scaling="Hex16"/>
Open up the ROM, navigate to the "Mods" section, change "Rear O2 Heater Patch" from "4A0B" to "0009"
My rear O2 has been replaced with the wideband.
This might also work but I need to confirm the address!
Code:
	<table name="Heater CEL" category="Rear O2" address="2c61e" type="2D" level="2" scaling="blobbits">
		<table name="Bit values" type="Static Y Axis" flipy="true" elements="8">
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>Rear O2 Heater CEL Enable</data>
			<data>N/A</data>
			<data>N/A</data>
			<data>N/A</data>
		</table>
	</table>
I think its a bad idea to do this all together. I believe doing this does not only disable the check, but disables the heater also. Someone else confirm if I am wrong... but if it does disable the heater it will destroy the rearO2 pretty quickly for those of us that still have it.
If you didn't know any better (and haven't set the emissions output correctly), it might also show a not-ready for that during an emissions test. It might be best to just leave this one alone, or include the definition but leave it stock.
Old Oct 11, 2009 | 01:40 PM
  #123
phenem's Avatar
Agreed. I was not going to add it to the patch I was just going to add the XML.
Old Oct 11, 2009 | 01:42 PM
  #124
Chris Moore's Avatar
Originally Posted by recompile
What I think Chris meant is, from the factory, the boost control is load based. However, the load value the boost control system uses is SLIGHTLY different from the load value the timing/fuel maps use. This is what he is referring to as the "stock" boost control system.
This was later patched to reference the same load value that the timing/fuel maps use. This is what he is referring to as the "2 byte" boost control system. Although that's a bit misleading/incorrect. What he should have said is the "common load"or "standard load" boost control system. But yes, the values of this "common load" does match up with what we all came to know as "2 byte load" and that's the point.
As far as 2 byte vs. 1 byte... the difference is only for logging. They both reference the same value, as far as the ECU is concerned for the various maps and for the actual tune. 1 byte exists as a logging improvement only.
Tephra, can you answer this question? Can we just add mrfreds patch like normal? So load based boost will follow a more consistent load.
Thanks
Old Oct 11, 2009 | 02:32 PM
  #125
R/TErnie's Avatar
Ok I read the whole thread. Excited for 88950715
I could've used the boost by gear at the track... I kept spinning 1st gear :/
Thanks Tephra, JoT, and Phenem for all of your work. Donation waiting when the 9's ROM is released!
Old Oct 11, 2009 | 02:59 PM
  #126
evodood's Avatar
subscribed
Old Oct 11, 2009 | 03:13 PM
  #127
tephra's Avatar
Thanks
Yes!
MrFreds patch changes the TBEC routine - which I don't touch.
Any scaling changes will obviously need to be applied to the new 3d BDEL maps instead
Old Oct 11, 2009 | 03:29 PM
  #128
Originally Posted by tephra
Yes!
Thank you sir
Old Oct 11, 2009 | 03:31 PM
  #129
drinky84's Avatar
Veteran: Army
Can some please explain the "Launch" fuel and ignition capability, would this be like a standalone ignition retard?
Old Oct 11, 2009 | 06:19 PM
  #130
03whitegsr's Avatar
Somebody care to comment on what Boost control maps are still relevant and which are not?
I want to eliminate any unneeded/replaced tables where every possible.
Old Oct 11, 2009 | 06:24 PM
  #131
tephra's Avatar
BDEL High Gear Range
BDEL Low Gear Range
BWGDC High Gear Range
BWGDC Low Gear Range
Are no longer in use. The rest are.
Old Oct 11, 2009 | 06:27 PM
  #132
03whitegsr's Avatar
Excellent, thank you.
Old Oct 11, 2009 | 06:38 PM
  #133
Vigman's Avatar
Will it be possible to include Mr Fred' temperature logging on version 7.1?
Having the V.7 + EGT logs will be the best rom ever for me!!!
Thanx Tephra for your great work! Will donate with 88590015' release ;-)
Cheers
C>
Old Oct 11, 2009 | 06:52 PM
  #134
Slo_crx1's Avatar
Just a thought for an add-in, might want to include the MAP sensor tables that can be adjusted for different map sensor types for logging in Evoscan. With the Omni 4 bar being a very viable option I'm sure you'll see quite a few more people using them compared to a stock Evo X type.
Old Oct 11, 2009 | 08:25 PM
  #135
GST Motorsports's Avatar
Tephra you rock!
You have paypal.
Does boost drop on knock go to 0% WGDC without BDEL correction applied? Is "High Knock Boost Drop and Knock CEL Flash time" the time that 0% WGDC is applied, then after that has elapsed it references WGDC map again?
- Bryan
