launch maps
Old Oct 18, 2009 | 07:39 PM
Chris Moore's Avatar
Originally Posted by recompile
This isn't thoroughly tested, but seems to build 15+ psi rather quickly. Using Timing Retard Limit mod to get -20. Stationary rev limit is at 6500
Care to share what number value your using with the timing retard limit mod to reach -20?
Old Oct 18, 2009 | 08:35 PM
project_skyline's Avatar
Actually this was a feature in V6.
My main interest is building boost and then transitioning to the main maps without tons of knock that would affect timing post launch.
Nice to see this thread has gotten some interest now. I'll post mine after I log results from it to compare.
Old Oct 18, 2009 | 09:15 PM
crcain's Avatar
If a stock power Evo can spin the tires... what would a big power Evo do with a ton of boost out of the hole? Isn't traction the issue for most people, not more power?
I've always dialed in NO ignition retard on my launch control settings with my autronic sm4 our of fear of breaking drivetrain parts. I get 1.6's with a 1.5 here and there. I even use a relay to my boost control solenoid to get less boost before a certain vehicle speed. So wanting to leave from 0 mph with a ton of boost seems odd to me. I'm sure if the drivetrain holds together and your on slicks and a well prep'd track you might cut a 1.3 or sumpin but is it worth the harrasment unless your a shop car?
Old Oct 18, 2009 | 09:39 PM
rolly1818's Avatar
Registered User
that video is hilarious! only in the caribbean!!!!
i want to test this - negative timing VS standard timing (8-10*)
some people say the retard is better others say the other.
i need V7 to test though i hate the knock the settings generate!
Old Oct 19, 2009 | 04:07 AM
recompile's Avatar
255/255 works for me on the IX ROM. As you can see, it builds 13 psi in less than a second
Old Oct 19, 2009 | 04:57 AM
hediki12's Avatar
...... wow ur cars moves 1257 hz of air @ 4687 rpm...... thats what my car does by red line. lol!!!! i realy need a new turbo... i hate this stock t25..
Old Oct 20, 2009 | 10:41 AM
Appauldd's Avatar
Logic....I followed your trend and made my launch maps. I have an FP Green and Revolvers so I had to tweek the fuel launch table too. I will post pics here soon.
Paul
Old Oct 20, 2009 | 12:09 PM
bnice01's Avatar
Just curious since I have no way of testing V7 since I am deployed but is there a retard timing limit in tephra v7?
Old Oct 20, 2009 | 12:21 PM
Yes, recompile just removed it on his maps I believe.
My comment was in reference to launch maps which were in tephra V6.
I can't comment on V7 i haven't yet loaded it into my car yet, i will today.
Old Oct 20, 2009 | 03:49 PM
Routybouty's Avatar
I wonder if the recover time is in a table somewhere. If we could lessen the time it waits before resuming power again I bet we could get some nasty boost quick!
On another note if I just get on the 2-step and then let off without launching my idle will stumble for a bit. It drops maybe 200rpm or so for about 10 seconds. My launch maps are identical below 3500rpm. With V7 that is.
Old Oct 20, 2009 | 08:42 PM
Appauldd's Avatar
As promised.....blurry for a reason.
Old Oct 20, 2009 | 09:14 PM
I would smooth out the fuel map more if it was mine.
Old Oct 20, 2009 | 09:44 PM
rolly1818's Avatar
Registered User
y not change the entire map to the desired AFR and timing?
it is not gonna affect your pull off if u set the parameters correctly.
Old Oct 20, 2009 | 09:48 PM
Appauldd's Avatar
To change the entire map wouldn't allow for smooth transition in fuel and timing. I believe that by doing that you may induce knock.
Remember....RPM has to increase to the set 2 step setting. Wouldn't you want it to do so smoothly and effectively?
Old Oct 21, 2009 | 05:38 AM
rolly1818's Avatar
Registered User
ohhhhh...good one....
