launch maps
Old Nov 4, 2009 | 10:35 AM
  #31
SyZyGy1394's Avatar
Originally Posted by Appauldd
As promised.....blurry for a reason.
Hows that map working out for ya?
Old Nov 4, 2009 | 12:34 PM
  #32
Appauldd's Avatar
It absolutly rocks ! ! 12psi boost at a launch set at 5500. Awesome !
Old Nov 4, 2009 | 12:55 PM
  #33
SyZyGy1394's Avatar
Are you getting any knock when it transitions from the launch map to your regular maps?
Old Nov 4, 2009 | 02:09 PM
  #34
rolly1818's Avatar
Registered User
he shouldn't be, it looks well "transitioned"
damn i need my V7!
Old Nov 4, 2009 | 02:19 PM
  #35
SyZyGy1394's Avatar
damn i need my V7!
I want v7 too, but I am waiting for SD to be implemented with the download.
Old Nov 4, 2009 | 02:27 PM
  #36
Appauldd's Avatar
No knock at all. Launch maps are great stuff. You just have to watch blowing your front diff launching by droping the clutch too fast.
Old Nov 5, 2009 | 09:50 AM
  #37
rolly1818's Avatar
Registered User
thats what i am scared of
Old Nov 5, 2009 | 11:03 AM
  #38
SyZyGy1394's Avatar
you on 93 oct?
Old Nov 5, 2009 | 11:13 AM
  #39
Appauldd's Avatar
Yes 93 octane.
Old Nov 5, 2009 | 12:22 PM
  #40
SyZyGy1394's Avatar
Yes 93 octane.
I'm tempted to ask to get those maps from you, but I don't know how much I should change the values because I'm on e85...
Old Nov 5, 2009 | 12:32 PM
  #41
Appauldd's Avatar
It is actually pretty simple to set up your own....
Set your stationary rev limit to your desired launch rpm....in my case 5500
Get the car warmed up and then log you bouncing off of the stationary limit.
Look at your log to determine where you need to add fuel and remove timing.
The ECU clips timing at -10 so it is pointless to enter less. (although some may desire less)
In the same area you remove timing, add fuel....and lots of it as the moments between rpm bounces will go lean.
Make sure you have smooth transitions in and out of the hole
Log again and make adjustments as necessary.
In my case, my initial settings above were a bit too lean and a tad too aggressive. I have since adjusted it quite a bit to make the launch smoother on the drivetrain. The weather is so cold now that I cannot launch without spinning the heck out of all the wheels. Thus I will have to wait to fully tune it until spring.
Old Nov 5, 2009 | 05:15 PM
  #42
chmodlf's Avatar
The info from Appauldd would explain that in the pre launch map world I would always SLOWL
Y squeeze the throttle. Otherwise I would get alot of knock. Probably still not a bad idea though.
Old Nov 5, 2009 | 05:23 PM
  #43
Appauldd's Avatar
This is very true.....DO NOT just mash the throttle....you will knock like mad.
Lay into the throttle easy and slow up to your stationary rev limit.
Hold the gas to the floor.......put it in gear.......prepare to hold the hell on.
Old Nov 5, 2009 | 06:17 PM
  #44
rolly1818's Avatar
Registered User
good point.
he can also try getting the ignition retard limit pushed. -20 timing would sound sexy , however, i am not sure you will get MUCH more boost or even need more.
my car lights up all 4 tyres with 10psi.
Old Nov 5, 2009 | 07:29 PM
  #45
Appauldd's Avatar
I too light up the tires at 10psi. It takes some finess to launch and not spin the tires.
