launch maps
Old Dec 1, 2009 | 04:07 PM
  #61
lan_evo_mr9's Avatar
Bump for the definition for 885 for -20 timing...
Old Dec 1, 2009 | 06:27 PM
  #62
GST Motorsports's Avatar
Tephra,
Is it possible to set this up for in between shifts to use as antilag?
Have a pretty serious build going on here and if I could get antilag working on the stock ECU that would be most excellent...
- Bryan
Old Dec 1, 2009 | 06:32 PM
  #63
JordanS4's Avatar
edit
Old Dec 1, 2009 | 06:46 PM
  #64
tephra's Avatar
yeah I guess I could put in some logic, so instead of speed we use top clutch switch?
let me know which is better
Old Dec 1, 2009 | 06:51 PM
  #65
The clutch switch would most likely work best for in between gear antilag I imagine.
You are the awesome
- Bryan
Old Jan 15, 2010 | 06:05 PM
  #66
Aman's Avatar
+ 1 for more antilag setup
Old Jan 15, 2010 | 07:29 PM
  #67
hediki12's Avatar
top clutch switch would be a sweet option since i have a dsm.. the switch we use broke on my car and im screwed so i only have a working top switch.
Old Mar 5, 2010 | 07:13 PM
  #68
Monochrome's Avatar
It'd have to be speed otherwise you'd dip into the launch map every time you shifted gears.
Old Mar 5, 2010 | 09:11 PM
  #69
chrisw's Avatar
You are the awesome
- Bryan
Now all we need is another table and pin out to drive an extra BCS solenoid for the SAS valve...
Old Mar 5, 2010 | 09:38 PM
  #70
SyZyGy1394's Avatar
Would be interesting if someone wrote something that would make a sort of mild antilag(software wise) for our cars.
Old Mar 25, 2010 | 08:58 PM
  #71
C130flyer's Avatar
I set my timing to -10 and fuel to 7.4 and when I get on the the 2 step it logs 30+ knock counts and the motor sounds like its beating itself to hell. Then once I come off the 2step the car idles funny and doesn't run right for about 15 seconds.
Old Mar 25, 2010 | 09:03 PM
  #72
Maybe because you are drowning it with fuel?
- Bryan
Old Mar 25, 2010 | 09:06 PM
  #73
C130flyer's Avatar
here is the map
Old Mar 25, 2010 | 09:13 PM
  #74
SyZyGy1394's Avatar
Uhh that is rather on the extremely rough side.
Old Mar 25, 2010 | 09:19 PM
  #75
BoostFTW05's Avatar
Hahah no doubt, Try setting your fuel just a few points richer and your timing to like -5 or -6 Thats where Ive had my best luck. It builds 15lbs which might be too much but I would rather blow the tires off then bogg out anyway
AC
