new live map app
Old Jan 1, 2013 | 04:17 PM
  #571
Broke4speed's Avatar
My live map won't run anymore . It says the beta has ended but when I download the 'new' version...same error pops up. Anyone else have this issue, or is it because I haven't donated?
Old Jan 2, 2013 | 12:02 AM
  #572
And's Avatar
And
if you donate Ziad will give you a registered version that should work forever then
Andy
Old Jan 2, 2013 | 12:23 AM
  #573
07EvoIX's Avatar
iv got a registered version and am getting the same error as well now.
cheers
Old Jan 2, 2013 | 12:48 PM
  #574
ziad's Avatar
I am mean........I put in hard limits so people well use the latest version....but then I am lazy and don't update the program..........
Lol, been on a very long holiday...back now, so will release and update, just got to work out where was I with bugs and all
Old Jan 3, 2013 | 01:48 PM
  #575
And's Avatar
And
you'd fixed the VE tracing in the last version I have
Old Jan 12, 2013 | 07:07 PM
  #576
ziad's Avatar
new version is up. a few changes. there are now additional maps that are in available in ram. but only for evo7/8/8mr (evo9 is under development)
but with the new version and the new maps, obviously u will need to repatch your rom. i recon repatch and then just copy the ign/fuel/boost etc tables back. also note the change in ecuflash xml due to moving the maf/injector scalings to ram, as u will need to update your ecuflash xmls otherwise you will cause issues.
Old Jan 13, 2013 | 02:35 AM
  #577
burgers22's Avatar
Thanks Ziad, looking good so far.
Old Feb 23, 2013 | 11:56 AM
  #578
gear head's Avatar
ziad, I just updated to the new version, updated ecuflash xml & re-patched my ROM(9653xxx6).
I am noticing that when I open the Alt Inj latency table in ecuflash using the address 38280 that the latency values are all jacked up, the MAF Comp table looks fine.
Should this be a concern or can I just input the correct values?
Old Feb 24, 2013 | 03:56 AM
  #579
ziad's Avatar
mate i will have a look through the code and get back to you. Is yours SD or normal MAF rom?
but first thing if you can do is see if the correct values are shown when u read injector latencies in RAM (in ELM). if they read as per what they should be. then most probably the address i gave u is wrong, which is more than likely the explanation here.
Old Feb 24, 2013 | 08:41 AM
  #580
gear head's Avatar
Yeah, I'm on 2d SD.
The car is currently down right now waiting for the parts to move a full size battery to the trunk, the PC-680 is completely shot. If I get some time later today I'll hook up a set of jumper cables & flash the new ROM in & check it out.
Old Feb 24, 2013 | 12:29 PM
  #581
ziad's Avatar
the autopatching feature is not recomended for SD cars, as i havent tested the patching there and possibility (even though a small one) that the autopatcher will overwrite stuff.
but i will investigate the problem regarding the table not showing up properly as it might be a mistake from me.
Old Feb 24, 2013 | 02:02 PM
  #582
gear head's Avatar
Ahh, makes sense now. Is there a good way to get both those tables into the 96533706 ROM?
Old May 10, 2013 | 12:33 PM
  #583
Monochrome's Avatar
What are the chances this app could be expanded work with the earlier generation (H8) ECUs? What information do you need? I've got most of the maps labeled out in several different ROMs for the EVO, DSM and 3000GT.
Old Aug 12, 2013 | 04:17 AM
  #584
DriftMonkey's Avatar
Hey Ziad, I was wondering if there were any updates for the evo 9? Thanks
Old Aug 12, 2013 | 04:23 AM
  #585
el.guerrero's Avatar
quoted ^
