EvoScan: 0% throttle = 13.73???
is this normal? when i'm at 0% throttle (decel, etc), my log shows 13.73. does this mean my TPS is not calibrated right or is it normal?
i show 100% when i'm actually at 100%... but if it's calibration is off... then it's gonna show 100% when i'm NOT.
i have no way to drive and watch the log.. nor do i have anyone to go with me while i tune, otherwise i'd know that way.
so. thought i'd ask. anyone?
As long as it displays 100% when the peddle is fully depressed, it's within it's operation envelope. The actual position at idle fluctuates between cars in my experience. Mine reads 15.2% or something like that at idle.
VERY wrong. The throttle plate should ALWAYS close fully when you let go of it. Its the Idle Air Control valve that regulates the amount of air that gets inside the engine when the throttle plate is closed. The ECU has NO CONTROL over the throttle plates position, its 100% mechanical.
To the OP, its within normal range but you CAN adjust the TPS sensors position so you get the full 0-to-100% swing.
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
Mine's the same, a buddy of mine who tunes Hondas says it wasn't normal or at least it's not like that on the Honduhs so i searched and it's normal.
Josh
what about us aftermarket TB guys. like the hypertune. the lowest i can get mine is 15.65 same with a few other guys i know who use this tb. i do get a 15.65 to 100% though.
EvoIX89
Jul 14, 2017 12:40 PM
Burnhad91
Aug 11, 2016 03:06 PM
03Ev0luti0n
May 16, 2011 07:27 AM
