ecu periphery2 6FDF
Old Nov 3, 2009 | 01:50 PM
mifesto's Avatar
ecu periphery2 6FDF
So broke down and bought an evo..... i get the infamous 0300 error so i went through the instructions in ....
https://www.evolutionm.net/forums/ec...0300-test.html
copied the appropriate html code for the older ecuflash versions (mine is 1.29). when i opened up the ecu periphery2, instead of a "EFDF" which it should be from factory, it has "6FDF" already in there.... so i dont want to take it out unless i know what it does...
now i dont know what this does as Junior tuned this car supposedly. (i seriously doubt he will share his secrets hehe)...
anyone know what 6FDF or in hex 0x6FDF does in the ecu periphery2?
Old Nov 3, 2009 | 02:10 PM
todd6027's Avatar
efcf disables po300 bits 4 and 5 set to 0
efdf has bit 4 set to 1
6fdf swiches off po443/446/403/243/090/2263 everything else stays same as efdf
Old Nov 3, 2009 | 02:20 PM
mifesto's Avatar
i dont think you understood my question (or maybe i didnt understand your answer haha)...
from factory it should be = EFDF and im suppose to change it to 6FDF
my question is what does 6FDF do?
Old Nov 3, 2009 | 02:25 PM
mifesto's Avatar
ok then what do you recommend i put in to disable all the above PLUS 0300?
fostytou's Avatar
EvoM Community Team
Take a second and read a bit more, then understand that you are representing multiple on/off bits with that hex code.
Smart moves would be to use ECUFlash v1.42. Not only does it have bug fixes and upgrades, it will include the blobbit maps that will allow you to independently disable certain periphery bits without working out the hex value you are trying to represent.
If you are really stubborn (or have some amazing good reason to) you can even install ECUFlash v1.42 after renaming your first ECUFlash directory to something like "ECUFlashv1.29" and still be able to bring up the old version if you need to.
See MrFred's detailed periphery mapping for more info. If you want to stick with old, broken times you can download the spreadsheet he made to convert a blobbit set to hex.
Old Nov 3, 2009 | 02:26 PM
mifesto's Avatar
my understanding is if i go to 1.42, ill have to buy the version 2 cables
Old Nov 3, 2009 | 02:48 PM
todd6027's Avatar
6fcf disables all the above plus 0300
Old Nov 3, 2009 | 07:47 PM
Evo_Jay's Avatar
1.42 works with 1.3U cables and the new openport 2.0 cable.
So you can upgrade.
mrfred
Apr 9, 2015 11:20 AM
ClixT
Lancer Engine Management / Tuning Forums
Jan 31, 2012 05:15 PM
mrfred
May 7, 2009 06:24 PM
troe666
Nov 4, 2008 01:44 PM
mrfred
May 6, 2008 09:30 PM
