Evo 8/9 ECU pins, pin removal & installation, and map switching harness how-to's
Which pin would I buy if I wanted to wire a boost solenoid into an "evo 8" ecu (actually a lancer ecu with the evo rom on it)? It doesn't seem to come with anything in there stock.
*edit* Looks like "small" pins are what I need
Hopefully there is somebody here that knows what I am after. All the pins, aka cam sensor pins the works, everything injector pins, anybody have idea where to find the specifics on those? I'm tired of crimping and soldering, so this winter i'm just going to redo the entire harness.
So chasebays has alot of the engine bay connectors. TPS AND SPEEDO, Injectors for hi and low z's, crank, cam, coil packs, even the ecu water temp connector. Only 2 i can't find right now are the front 02 sensor plug and the iac plug.
deeman101
Mar 3, 2021 07:56 AM
Jack_of_Trades
31
Nov 5, 2009 11:18 PM
