**Need Help setting up V7???** Here is your answer
Old Apr 8, 2010 | 01:23 AM
  #211
ace33joe's Avatar
Originally Posted by Raceghost
Anyone seeing an issue with the gear based boost crossover. No 6 th gear here, and I just copied what was in the 5th gear location to 6th gear? Same goes for the 0 column...? Does this function work strictly off of the speed to gear? I dont need the MAT sensor upgrade. i am still on MAF. I assumed when i read the initial post by MFRED that it would run on the stock MAF.
Also, trying to tune and the boost error in my logs stays the same, -3.048...any thoughts?
The boost is registering, the WGDC is registering, I have verified the EvoScan deffinitons are correct, running out of thoughts.
My ROM deff is 94170715.
Thanks in advance.
Tephra himself is working on it. I have the same problem as you.
https://www.evolutionm.net/forums/ec...-issues-3.html
Old Apr 8, 2010 | 01:31 AM
  #212
Raceghost's Avatar
Which is your problem, the gear based boost, or the boost error not reading even when changing the hex addresses?
THanks again for the heads up.
Old Apr 8, 2010 | 01:35 AM
  #213
ace33joe's Avatar
I have both problems (gear is stuck at 1, and boost error is not reading right), and the hex address fix is the first attempt for solving the gear-based-boost-control function. I haven't had a chance to test the hex fix solution yet. I will do it tonight see if it solves the problem. You can try it yourself too.
Old Apr 8, 2010 | 04:49 AM
  #214
theopetridis's Avatar
Hi
First post here. I have been reading a lot though.
I have a JDM EVO VIII. I have crossed over to V7 96530706 in the last few days and before that 9626009 tephra v5
What I have understood reading my logs through Evoscan (logging 1 byte load) is that the ECU sees a lower load than the Evoscan sees, by a factor of 1.1 approx. I say that because I log advance and the ign advance in my map shows different values than the ones that I get.
For instance in 240 load and 4000 rpm I should have an advance of 2 degrees according to my map, but I log 6 degrees (which corresponds to a load of 220 and 4000 rpm)
I have started looking at older logs (96260009 with 2 byte load) and I see the same there.
What could be the problem and how can I fix it?
Thx in advance, keep up the good work
Old Apr 8, 2010 | 06:23 AM
  #215
phenem's Avatar
Anyone seeing an issue with the gear based boost crossover. No 6 th gear here, and I just copied what was in the 5th gear location to 6th gear? Same goes for the 0 column...? Does this function work strictly off of the speed to gear? I hope I dont need the MAT sensor upgrade. I am still on MAF. I assumed when i read the initial post by MFRED that it would run on the stock MAF.
Thanks in advance.
Did you setup your RPM/Speed to define all your gear crossover points?
Check out the wiki for help: http://evoecu.logic.net/wiki/Main_Page
Old Apr 8, 2010 | 11:54 AM
  #216
Raceghost's Avatar
I have an 04 VIII and the tables set similiar to
As for the gear based boost control, you need to make sure to set up the "RPM Speed to Gear" table properly.
0 6
43.3186 5
61.9912 4
84.6903 3
117.301 2
176.195 1
2899.78 0
"Main Map Wastegate Duty" for the 0 and the 6 gear columns should be all 0
Old Apr 8, 2010 | 12:22 PM
  #217
Originally Posted by theopetridis
Hi
Any ideas?
Is there a chance my MAF readings are off? Wouldn't that affect my 1byte load as well?
Old Apr 8, 2010 | 03:30 PM
  #218
Silk's Avatar
So I have a problem; I successfully converted my 96940011 rom to a phenem V7 96530706 rom and got the car running well with the new rom. I did this last night but when I tried to open my saved V7 rom today, none of the V7 tables appear, only the tables I had on my stock 96940011. And when I open the tables all the axis and values are gibberish. I read the image off the ecu and got the same result. Also when I look under the ROM Id, it still says 96940011 after internal ID. What am I missing. Also car still runs with all the tephra options I had setup yesturday.
Old Apr 8, 2010 | 05:31 PM
  #219
phenem's Avatar
Sounds like when you were copying over all the tables you copied over the ROM ID to the v7 ROM. Change that back to 96530706 and save, then re-open and you should see all your data again.
P.S. - don't ever change the ROM ID unless we tell you to....
Old Apr 8, 2010 | 08:01 PM
  #220
Silk's Avatar
That fixxed it, Thank you very much
Old Apr 9, 2010 | 11:26 PM
  #221
Bump for an answer
I know I am a newbie. I would really appreciate some ideas.
Thx
Old Apr 10, 2010 | 04:49 AM
  #222
Fast_Freddie's Avatar
Veteran: Navy
Theo, this is most likely due to the interpolation of surrounding cells ...
Old Apr 10, 2010 | 10:21 AM
  #223
Thx Freddie, but I don't think so.
The map is pretty smooth and I see large differences in logging.
To test this I flashed the original rom back on the car (93660005) and logged today. I saw that that happened even with the original rom. I get more advance than what I have in the maps for the high cells (>200 load ) and less timing than the map for the low cells (<100 load).
How does the ECU decide what load to take in account in order to decide the timing? (I logged 1 byte load, load calculated, 2byte load and the result was the same). Because my timing is unpredictable.I end up with the timing for 230 load when in fact the load is 260.
Is there an error somewhere? I think I have tuned around it but something is not right I think
Old Apr 10, 2010 | 12:45 PM
  #224
nothere's Avatar
I think you can have issues with what is logged in load depending on the version of ecuflash and evoscan you are using. Do you have a recent evoscan and ecuflash? say 2.6 and 1.4xxxx
also, sorry for the thought, make sure its 1byte you are logging and not 1byte4 or whatever it is.
Old Apr 10, 2010 | 05:58 PM
  #225
Veteran: Navy
Also make sure that your 1byteload factor matches in ECUflash and Evoscan...
