**Need Help setting up V7???** Here is your answer
Old May 5, 2011 | 11:05 AM
  #361
erickponce's Avatar
Does anyone know if it is possible to run the aem 3 or 5 bar map sensor in place of the JDM sensor. If so where would you change the scaling for the sensor?
Old May 5, 2011 | 11:15 AM
  #362
erickponce's Avatar
not on SD. I just need to see if i can switch between my stock ecu and my AEM EMS without changing sensors
Old May 9, 2011 | 11:57 AM
  #363
HornstarBU's Avatar
I think this is what you want, not 100% sure, but I think. You basically want to see the VE stuff that you use for speed density, although I know you're not running it, but you set the stuff you would set for changing a MAP sensor to whatever your aem 5bar uses. I think it's in this thread though
https://www.evolutionm.net/forums/ec...sdm-8-9-a.html
Old May 10, 2011 | 12:06 PM
  #364
erickponce's Avatar
^ thanks man
I looked through it and it has a lot of usful info. I see that the xml file has all the scalings for different map sensors but i dont know how to change to wich one im using. Maybe thats just an option on the SD versions.
Oh well I suppose. Changing the MAP isnt bad anyway
Old May 11, 2011 | 05:59 PM
  #365
kevo31's Avatar
hey, I'm converting to the v7 96530706 from my stock 94170008, tonight i flashed the new rom to my ecu and it starts then immediately stalls. I copied over all the fuel and timming maps, the immobilizer and all the idle settings, any one have any suggestions?
thanks
Old May 11, 2011 | 06:15 PM
  #366
Fast_Freddie's Avatar
Veteran: Navy
disable the immobilizer in periphery and see if it starts and runs then...
Old May 11, 2011 | 07:07 PM
  #367
kevo31's Avatar
Disabled immobilizer but still nothing. Any other ideas? Car stalls right away.
Old May 21, 2011 | 01:12 AM
  #368
utripin's Avatar
not starting
What was the last thing you did to the car? Anything besides the flash?
Old May 21, 2011 | 03:06 PM
  #369
todd6027's Avatar
Is valet mode enabled ???
Old May 26, 2011 | 03:58 PM
  #370
Timmay81's Avatar
can anyone explain how to use the Big map translator?
Old May 26, 2011 | 05:46 PM
  #371
dparrish's Avatar
The simplest way:
  1. Open your current ROM in Ecuflash
  2. Open the Fuel Map 3d map, select all the cells and hit Ctrl-C to copy
  3. Paste the map into the top part of the bigmap translator spreadsheet. Make sure you move the 110000 cells to the correct place
  4. Select the whole bigmap down the bottom of the spreadsheet and Ctrl-C
  5. Open your new ROM in Ecuflash (the one with the bigmap) and open the "Main Fuel Map" map.
  6. Select the top-left cell and hit Ctrl-V
This is the very simple way of doing it. It probably won't give you a smooth map and you may need to check each cell to make sure it's correct. Perhaps use the smoothing spreadsheet.
Old May 26, 2011 | 11:57 PM
  #372
Timmay81's Avatar
thanks for the explanation ,but still cant get it figured out
im just gonna go back to v5 as this seems like way to much work for the average user
Old May 30, 2011 | 11:56 AM
  #373
Diego 10's Avatar
I guys I'm trying to run my car with tephrav7 on my evo IX I read on main topic that for my rom (88840016) the right one is 88580714 I change immo but the car does't start at all...Someone has any idea about!?!
Thanks so much
Old May 30, 2011 | 04:52 PM
  #374
dparrish's Avatar
I don't know if it's the same on a IX as on my VIII but there are 2 immobilizer codes in the rom. "Immobilizer" and "Immobilizer Hex", make sure they are both the same.
I couldn't get mine to start at all after moving from the stock 96260009 to the 96530706 so I had to disable the immobilizer in the Periphery bits. It's not ideal but it starts. I have an aftermarket remote immobilizer installed as well so people can't start the car with a screwdriver.
Old May 31, 2011 | 04:11 AM
  #375
Diego 10's Avatar
Thanks so much dparrish...on my v7 rom 88580714 i can't see immobilizer hex...I think that I have to try to disable the immo like you...but it's not the best....it will be interesting if someone can help us for solve the problem and mantein our immo....
