**Need Help setting up V7???** Here is your answer
Old Sep 20, 2011 | 08:02 AM
  #421
DSMolition's Avatar
Yours fires up, idles for a sec or 2, then the rpm's fall too fast and it dies, right? This is exactly what it does.
Old Sep 20, 2011 | 10:48 AM
  #422
HornstarBU's Avatar
Yup, if you pump the gas a little can you get it to stay running? Did you change the immobilizer to match your car? or try disabling it through periphery just to see if that's it. Make sure to copy over ISCV tables from your original rom.
Old Sep 20, 2011 | 12:48 PM
  #423
DSMolition's Avatar
No, if i pump the gas it still dies just as fast. sorry for being such a newb I’m trying to teach myself all of this. How do i copy over the ISCV tables from the factory rom?HoW do i change the immobilizer to match my car? Im going to mess aoround with it after work to see if i have something on i shouldnt have. Thanks the help
Old Sep 20, 2011 | 01:44 PM
  #424
Spec-Ops1's Avatar
It is most likely the immobilizer... it is listed as immobilizer in the rom... copy it from your old rom...
Old Sep 20, 2011 | 01:55 PM
  #425
ddb's Avatar
ddb
I'm setting up V7 psi based, i'm wondering since i have 5 spd do i have to change something in rpm\mph to gear in order to have gear dependant psi.
Old Sep 20, 2011 | 03:25 PM
  #426
HornstarBU's Avatar
I'm going to need to know the answer to this pretty soon, since I'm going to be getting gear based going as well...and I've got a totally different transmission than you guys, so if someone chimes in, can you also say how that actually works? Is the value in the table the middle of the RPM range? the top/bottom?
Old Sep 22, 2011 | 02:41 AM
  #427
ddb's Avatar
ddb
Here's what i found. Rpm\mph is always the same in the same gear it is simply the rpm at a given time divided by the mph at the same time.
So for instance, if you are driving at 4000 rpm and 65 mph in 4th gear your ratio would be
4000\65= 61.54.
You just have to log for each gear and you will have your ratio.
Old Sep 22, 2011 | 06:33 AM
  #428
HornstarBU's Avatar
4000\65= 61.54.
It makes so much sense when you spell it out like that....now I feel stupid
*that's why they call them GEAR RATIO's*
Old Sep 23, 2011 | 05:21 AM
  #429
DSMolition's Avatar
Thanks guys it was the immobilizer. It works grate now.
Old Sep 23, 2011 | 03:58 PM
  #430
catman78's Avatar
Can't log WGDC Correction
Hi,
I'm using OMNI 4-Bar. ROM 96530706
Evoscan 2.8 Log reads all 0's for WGDCCorr
Here's my settings
Old Oct 9, 2011 | 07:40 AM
  #431
Evo8RLK's Avatar
[QUOTE=HornstarBU;9616208]I use the most recent beta version of ecuflash so I can do stand alone sd card logging, but I don't suggest you do that. The reason I mention it is that is has "compare roms", does the version you have do that as well? If so, open your rom and the 9417 rom you want, and compare the 2 copying things over as necessary. As far as maps, just look at comparable load columns and rpm and fill in the data to match, use H and V to interpolate between when you don't have the exact value.
Alright i got mostly everything switched over.. well of it and it started up and took it for a test drive and drove normal.. but when i logged with evoscan everything is messed up.. like load, TPS ect.. need heeeelp!
Old Oct 11, 2011 | 09:07 PM
  #432
sivs's Avatar
maf scaling and smoothing
my 9417008 rom has maf scaling and maf smoothing in it.
tephra has maf scaling with adder.
stock rom has these load columns in units
192
256
512
768
1024
1280
1536
1792
2048
2304
2560
2816
3072
4096
5120
6144
8192
10240
12288
14336
16384
and v7 has columns in hz
18.87
25.16
50.32
75.48
100.64
125.8
150.96
176.12
201.28
226.44
251.6
276.76
301.92
402.56
503.2
603.84
805.12
1006.4
1207.68
1408.96
1610.24
basically how do I convert my tuned current maf setting over to the v7 rom. thx
Old Oct 11, 2011 | 09:45 PM
  #433
HornstarBU's Avatar
192
256
512
768
1024
1280
1536
1792
2048
2304
2560
2816
3072
4096
5120
6144
8192
10240
12288
14336
16384
18.87
25.16
50.32
75.48
100.64
125.8
150.96
176.12
201.28
226.44
251.6
276.76
301.92
402.56
503.2
603.84
805.12
1006.4
1207.68
1408.96
1610.24
Just match the same scalings for both of them, then copy....you might have to add a scaling for one or the other xml.
Old Oct 20, 2011 | 10:09 AM
  #434
evo 9 guy's Avatar
Need Help!!!
I am hoping this is the correct spot for this, but here it goes.
I finally got the xml information loaded to the metadata folder for the evo section. When I open the ROM in ECUFlash it will allow me to look at everything except the TephraMod section. If I try to scroll down to look at the bottom protion of the options it will close ECUFlash all together; however, if I minimize TephraMods or use look at my current rom without TephraMods I have zero issues and can look at everything.
I hope this makes sense and can get this figured out.
Thanks for any help.
Old Oct 20, 2011 | 11:12 AM
  #435
HornstarBU's Avatar
Mine does this too. I scroll down slowly through the list of items, and see what the last thing I can see is before it closes. Then I open the XML file, and remove that next item, save the file, see if it opens. IF it doesn't, I remove the following item, and it typically opens.
Another thing is, if it closes instantly, make the window (ecuflash) smaller, and then open the file, so only 1 item is showing on the left side.
